Bad drive or Bad Flash?
supawiz6991
#1 Post by supawiz6991 » Tue Dec 19, 2023 8:18 pm
Hi All,
I recently replaced my failed WH16NS40 with another of the same model. I flashed it to 1.02 and while it does the initial disc read and shows me the track listing, regardless of what type of media I put in (UHD, Bluray, DVD, Kraft Singles) it fails ripping.
I get numerous "The source file --- is corrupt or invalid atg offset xxx, attempting work around", "Hash check failed for file ----, at offset xxx, file is corrupt." with a final error of "Too many hash check errors in file ---, Failed to save file".
Those same discs work fine in my WH14NS40 drive.
Is this a case of the LG duds or could there be a firmware problem? I did reflash 1.02 but that didn't help. I don't have a copy of the stock firmware (forget to my a backup like an idiot) to revert back to.
Re: Bad drive or Bad Flash?
#2 Post by Billycar11 » Tue Dec 19, 2023 8:36 pm
Nah probably bad drive return it and get a pioneer they are way better see below I have ones with old fw.
supawiz6991
#3 Post by supawiz6991 » Tue Dec 19, 2023 10:28 pm
Billycar11 wrote: Tue Dec 19, 2023 8:36 pm Nah probably bad drive return it and get a pioneer they are way better see below I have ones with old fw.
I've considered getting a pioneer drive before...the price was just a little too high for my budget. For now, The return window is still open on this drive so for now I'll make Amazon replace it BUT I will start putting money aside for one of the pioneer drives so I can eventually move away from LG.
#4 Post by Coopervid » Wed Dec 20, 2023 1:10 pm
supawiz6991 wrote: Tue Dec 19, 2023 10:28 pm
Check PM.
