Hello, i'm new to this forum, i'll cut to the chase:
I bought a ASUS BW-16D1HT, it was manufactured Jan 2018. I've just plugged it in using a powered SATA -> USB adapter from UGREEN and hooked up to MakeMKV.
The drive does not seem to work. I place a disc in the drive and it will spin up for around 2 minutes before hitting me with a "no disc inserted" message.
I have tried to install firmware from the All You Need pack, as well as use asus' utility to revert to 3.10.
I have additionally cleaned the sensors and tried again with no avail.
I have used DVD, CD, Blu Ray. 2 types of each. None seem to work.
Is this drive DOA?
Is this ASUS BW-16D1HT DOA?
Re: Is this ASUS BW-16D1HT DOA?
Does the OS recognize the disc before launching MakeMKV?
What Info/LibreDrive Info does MakeMKV report?
It's possibly the SATA -> USB adapter? Or, not. Not all fully support ATAPI devices.
Hello, i'm the original poster of this thread. (I lost access to that account lol)
The adapter from amazon was sent with a 5v power adapter. These optical drives run on a 12v connection, and thus, it was not spinning up correctly. I'm surprised it isn't bricked.
I had to find a cable which was 12 volts and after plugging it in, literally worked OOTB as if nothing happened.
Software is working fine. I am now ripping a few blu-rays for my family.
I will buy this software later should I get the time.
For a summary, I am using a ASUS BW-16D1HT Blu Ray drive with a UGREEN SATA to USB connector. The issue was the plug that was sent, despite being called a 12v plug, was not actually 12v.
Opening MakeMKV and it did pick up the drive and all the details; so did windows. It was only erroring when inserting discs. Due to power restraints. I was able to flash firmware and revert and do everything except for ripping.
I plugged the drive into my Linux machine and it was pretty obvious something wasn't right after running "journalctl -b" and seeing all these errors relating to "power reset".
I checked the cables and made sure connections were secure; and after checking more thorough. Thats when it was discovered that it simply was not getting enough power.
So ultimately; check when you use a USB/SATA connector that the supplier sends out the correct power adapter alongside it.
I hope this helps someone else along the way.
