Error message:
"The volume key is unknown for this disc - video can't be decrypted
Backup failed".
Here's the disc information:
Protection: AACS2.0/C v76
I have also attached the AACS dump file.
Please fix, Thank you!
NO TIME TO DIE UHD Issue
Re: NO TIME TO DIE UHD Issue
Not seeing a file, and it should be EMAILED to svq@makemkv.com in any case. You would only need to post the NAME of the file here, to show which one your generated request was for.
apollo123
Yes I've already emailed it a few hours ago.
Strange, I thought I uploaded. I'll try again here. I get a triangle below the status when I try to uploaded it. When I click on the triangle it says: "Sorry, the board attachment quota has been reached."
Here's the file name: MKB20_v76_NO_TIME_TO_DIE_2DD7.tgz
(If you don't see the attachment of the file then I've uploaded it on WeTransfer here's the link for it):
https://wetransfer.com/downloads/0c845e ... 835/7243f2
Emailing the file is the correct answer; you don't need to upload it to the forum. Posting the name of the file you emailed to the forum is a good thing to do however.
It is possible that No Time to Die (2021) has a new pressing with a new key needed for decryption. It might also be the case that your computer is having trouble downloading the necessary keys. Was there a message about a download failing or being disabled?
Fixing Volume Key is Unknown
hkdata.crabdance.com or hkdata.fairuse.org not found
apollo123
Thanks for letting me know.
No, neither of those messages appeared.
