Can't extract all titles from CSI Season 1 BlueRay
tabish121
#1 Post by tabish121 » Sat Jul 16, 2011 9:24 pm
Just got the CSI Season 1 BlueRay set and having issues Ripping some of
the episodes from certain discs. I've attached the requested debug
info.
The tracks that do come off the disc are not able to be played, at least
there's no video anyway the audio seems to be ok. I've tried playing
back the files with VLC and SMplayer and neither can show the video.
The discs work fine in my BlueRay player though.
Using the latest v1.6.12 on Fedora 14 x64
Re: Can't extract all titles from CSI Season 1 BlueRay
#2 Post by mike admin » Sun Jul 17, 2011 11:00 am
The M2TS file is corrupted. Please try making a full disc backup with MakeMKV and see if any hashcheck errors show up.
tabish121
#3 Post by tabish121 » Mon Jul 18, 2011 12:46 pm
Did a full backup last night and get errors when trying to extract the titles from the backup, no errors occurred during the backup process. Log attached.
tabish121
#4 Post by tabish121 » Fri Sep 23, 2011 8:55 pm
Attempt to extract the disc again using v 1.6.15 and still fails on the same title.
MakeMKV_log.txt
(17.71 KiB) Downloaded 1903 times
#5 Post by mike admin » Sun Sep 25, 2011 10:35 am
tabish121 wrote:Attempt to extract the disc again using v 1.6.15 and still fails on the same title.
Unfortunately it IS a bug in MakeMKV and more information may be needed. How soon the error happens after you press "Make MKV" button? Where is the progress indicator - somewhere at start, in the middle or at the end?
tabish121
#6 Post by tabish121 » Sun Sep 25, 2011 1:48 pm
Saving 1 titles into directory /downloads/Video/CSI_S1_D2
DEBUG: Code 179 at 9{.h}X@7*PC(w=Q>J]n>:29395609
DEBUG: Code 0 at UI.znRq^,P'5_}df%NH6:29394183
DEBUG: Code 140070 at UI.znRq^,P'5_}df%NH6:29393309
Failed to save title 4 to file /downloads/Video/CSI_S1_D2/title04.mkv
0 titles saved, 1 failed
It happens pretty much right away, only a few seconds after the "Saving 1 titles" log statement as seen above.
tabish121
#7 Post by tabish121 » Fri Oct 28, 2011 9:22 pm
Tested against version 1.6.16 produces the same result
Saving 5 titles into directory /downloads/Video/CSI_S1_D2
Forced subtitles track #4 turned out to be empty and was removed from output file
Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
DEBUG: Code 179 at #[c<L8$3]D_E@WCcy;EK:29395609
DEBUG: Code 0 at m;S>l?09e7-cp!$%jD$g:29394183
DEBUG: Code 140070 at m;S>l?09e7-cp!$%jD$g:29393309
4 titles saved, 1 failed
tabish121
#8 Post by tabish121 » Fri Dec 23, 2011 1:31 pm
Still failing to as before with version 1.7.0, debug log attached.
MakeMKV_log.txt
(12.7 KiB) Downloaded 2056 times
spyderreve
#9 Post by spyderreve » Sun Mar 02, 2025 3:23 pm
Hate to revive a dead thread but was a solution to this ever found? Having the same issue trying to rip disk 2 from this season.
#10 Post by dcoke22 » Sun Mar 02, 2025 4:41 pm
spyderreve wrote: Sun Mar 02, 2025 3:23 pm Hate to revive a dead thread but was a solution to this ever found? Having the same issue trying to rip disk 2 from this season.
What does your MakeMKV log say? Please copy & paste the contents into a post here on the forum.
