Issue Ripping UHD LotR two Towers Disk 2
Re: Issue Ripping UHD LotR two Towers Disk 2
Right now, we know "it doesn't work". Maybe if we had additional information, like the errors encountered, we could comment.
routeweave
Post by routeweave »
Just got this disk, and I'm also having issues ripping it. When I put the disk in the drive, it takes a long time to register. Then when I try to index the drive, it lists several errors and often fails. The drive also is making some strange clicking sounds during this time. Sometimes it does successfully list the tracks, but after it shows the list my drive starts to spin very quickly and then briefly after reports as having "no disk". Here is the log from the moment I insert the disc through it indexing the disk:
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLHO3SD5922' at offset '33366081536'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLHO3SD5922' at offset '33366145024'
udf: node fe/efe failed!
Using LibreDrive mode (v06.3 id=7FA2657C7667)
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLHO3SD5922' at offset '33368113152'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLHO3SD5922' at offset '33366736896'
Failed to load content hash table, unable to verify integrity of M2TS files.
Using Java runtime from C:\Program Files\BellSoft\LibericaJDK-14\bin\java.exe
Title #00005.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.mpls has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.mpls has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00009.mpls was added as title #0
Title #00010.mpls has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.mpls has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00027.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00049.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00050.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00075.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00093.mpls was added as title #1
Title #00153.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00452.mpls was added as title #2
File 00803.mpls was added as title #3
File 00806.mpls was added as title #4
Title #00000.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00101.mpls is equal to title 00093.mpls and was skipped
Title 00102.mpls is equal to title 00093.mpls and was skipped
Title 00804.mpls is equal to title 00803.mpls and was skipped
Title 00805.mpls is equal to title 00803.mpls and was skipped
Title #00004.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00008.m2ts was added as title #5
Title #00009.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00033.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00037.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00052.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00059.m2ts was added as title #6
Title #00068.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00071.m2ts was added as title #7
File 00073.m2ts was added as title #8
File 00074.m2ts was added as title #9
Title #00000.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
From what I have seen, these errors are related to the drive being unable to read certain segments on the disk. This disk came straight out of a new box, but there are now some very slight surface blemishes (I'm guessing from the aggressive movements in the drive). The drive is still reading other 4k blu-rays fine. I have cleaned the disk, but maybe I need to try again more thoroughly. Let me know if there is anything else I should try.
jtsapps217
Post by jtsapps217 »
I am having the same issue. I tried using the backup feature, then ripping to MKV, same result. Also tried creating ISO and backup files with other software, same result. I can't seem to figure this one out. Any other tips would be appreciated.
