She Hate Me DVD causes drive to disconnect?
MrRobert
I have a very weird issue with the DVD She Hate Me. I'll rip the DVD like normal and about half way through I get a message that No Optical Devices are detected. I have to close MakeMKV then open it again to get it to detect my DVD drive. This doesn't happen with any other DVD but happens with this DVD every time.
Re: She Hate Me DVD causes drive to disconnect?
What OTHER messages do you receive? Generally, for a disk to "disappear" like this, it has to have stopped responding... which normally is proceeded by error messages. For example, if a disk becames hard to read, you will see the data "pause" as the drive retries a sector multiple times. Sometimes, the operating system will simply decide the drive has disconnected, as it continues to retry reading the disk.
Does cleaning the disk change where it happens?
MrRobert
The disk looks pristine with no scratches. I have cleaned it multiple times anyway.
I tried ripping it again to see what other errors occur and it failed to even open the disk.
I got the following.
Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' occurred while reading 'BD-RE TSSTcorp BDDVDW SE-506CB TS02 S15E6YKG90019N' at offset '3414724608'
Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' occurred while reading 'BD-RE TSSTcorp BDDVDW SE-506CB TS02 S15E6YKG90019N' at offset '3292051456'
Cells 1-2 were removed from title start
Title #1 declared length is 2:13:27 while its real length is 1:08:07 - assuming fake title
Title #2 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 1-1 were removed from title start
Title #4 declared length is 0:08:14 while its real length is 0:00:00 - assuming fake title
Title #5 has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 has length of 105 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 87 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #8 has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10 has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11 has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #14 has length of 115 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #16 has length of 106 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #17 has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
I cleaned it again even after cleaning it numerous times it opened the disk and I got this.
Saving 1 titles into directory C:/Video/She Hate Me
Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' occurred while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '3112960000'
Error 'OS error - A device which does not exist was specified' occurred while reading '\Device\CdRom2' at offset '3112960000'
Failed to save title 0 to file C:/Video/She Hate Me/She Hate Me-A1_t00.mkv
0 titles saved, 1 failed
