Oppenheimer / MI:7 Dead Reckoning 4K not recognized
knyght1
#1 Post by knyght1 » Sat Dec 16, 2023 9:26 pm
I have a flashed BD drive WH16NS60 that successfully recognizes and rips other UHD discs but for some reason it won't recognize Oppenheimer or MI:7
Any suggestions?
Re: Oppenheimer / MI:7 Dead Reckoning 4K not recognized
#2 Post by dcoke22 » Sat Dec 16, 2023 9:56 pm
Can you post a log? Or be more detailed by what you mean by 'won't recognize'?
For Oppenheimer at least, it seems some people are able to rip it. Oppenheimer (2023)
knyght1
#3 Post by knyght1 » Sat Dec 16, 2023 10:02 pm
I mean the drive spits the disc out
#4 Post by dcoke22 » Sun Dec 17, 2023 5:20 pm
I suppose that means the drive can't read the optical disc. Have you tried gently cleaning the disc?
knyght1
#5 Post by knyght1 » Sun Dec 17, 2023 5:39 pm
It's a brand new disc. I just opened it. I tested all my older 4K discs and it reads them. Does the drive have to be updated somehow?
#6 Post by Woodstock » Sun Dec 17, 2023 6:10 pm
"Brand new disk" means very little if the disk is a defective new disk, at least as far as your drive is concerned. Sometimes a drive won't even spin the disk, Are you hearing it spin? Does it work with a different disk?
knyght1
#7 Post by knyght1 » Sun Dec 17, 2023 6:19 pm
It is spinning the disc. Then it makes some weird sounds. Does this for awhile then eventually ejects the disc. I understand a brand new disc can be defective but it is happening with both my new movies Oppenheimer and MI7. Seems unlikely that both new movies are defective. Again, it plays all older 4K titles.
#8 Post by dcoke22 » Sun Dec 17, 2023 6:37 pm
Assuming your WH16NS60 is on the recommended 1.02MK firmware, your drive does not need to be updated.
I've had to clean brand new discs before. Sometimes they seem to end up with a nearly invisible film on them. I think it might be left over from the pressing process and it wasn't sufficiently cleaned or it might be deposits from off gassing of the plastic case.
I'd try gently cleaning the disc. Since the drive works with other discs, the laser optics in the drive are probably fine, although they can get dirty over time as well. If that doesn't work, then I'd try exchanging the discs while you're in the return window.
knyght1
#9 Post by knyght1 » Sun Dec 17, 2023 6:46 pm
My firmware is 1.00 --
Product: BD-RE WH16NS60
Revision: 1.00
Serial number: M6AJ3MK1329
Firmware date: 2117-04-25 17:56
Highest AACS version: 81
Firmware version: 1.00
#10 Post by dcoke22 » Mon Dec 18, 2023 3:07 am
I think the 1.00 firmware is also fine, but I'm not the best person to answer that.
#11 Post by SamuriHL » Mon Dec 18, 2023 3:27 am
It's fine in terms of firmware. It's just that these lg drives suck. I was trying to use 2 of mine earlier for FindVUK reasons and ended up giving up and just using my bu40n. I'm so much happier when using my pioneer drives for actual disc processing. Using the ns60s makes you appreciate the pios even more. Both of my ns60s had problems just recognizing discs, much less trying to read from them. The bu40n had no such problems. Granted, I was trying to read about 50 discs today, but the ns60s just couldn't do it on at least half of them.
And while the bu40n at least read the discs properly, it doesn't come close to the pioneers.
