Trouble With Gilmore Girls
fradster
#1 Post by fradster » Wed Dec 13, 2023 5:25 am
Hi, I've been fighting some errors trying to get Gilmore Girls DVDs done.
I have errors that I can't overcome on Seasons 2, 5, and 7 and have ordered "like new" copies to try.
Season 5 arrived today and one of my trouble discs worked perfect, but 2 others are still arguing. It is the same dang episodes as the first set of discs too. I didn't compare the logs line by line between standard and manual mode (but seemed the same) and it doesn't appear to make a difference which optical drive I use (I have 2).
Here are logs that are produced from Season 5, Discs 1 and 3.
I've read and tried all the troubleshooting I can find in the faq and forum - any other ideas?
MakeMKV v1.17.5 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\username/MakeMKV_log.txt
DEBUG: Code 100864256 at T*66mI"9R%2H!-6CI':121263429
DEBUG: Code 100864256 at T*66mI"9R%2H!-6CI':121262302
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading 'HD-DVD-ROM HL-DT-ST BDDVDRW GGC-H20L 1.03 K2288CB1856' at offset '3888152576'
DEBUG: Code 1 at EE1&1)+=_<_1Ic0}mJ@_H`g:29395586
DEBUG: Code 1898512 at EE1&1)+=_<_1Ic0}mJ@_H`g:213131939
DEBUG: Code 19869 at !\uy]#z`q,hoIpd~itA.:213133250
DEBUG: Code 16777216 at !\uy]#z`q,hoIpd~itA.:121265062
DEBUG: Code 0 at !\uy]#z`q,hoIpd~itA.:29394689
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading 'HD-DVD-ROM HL-DT-ST BDDVDRW GGC-H20L 1.03 K2288CB1856' at offset '3620278272'
DEBUG: Code 1767714 at EE1&1)+=_<_1Ic0}mJ@_H`g:213131939
DEBUG: Code 0 at "NLX^`Ns%Dx_%F:29397104
DEBUG: Code 1898863 at pXS,3wO=BO$DR(:29396184
DEBUG: Code 1898864 at pXS,3wO=BO$DR(:213132721
DEBUG: Code 2489208 at pXS,3wO=BO$DR(:213132721
DEBUG: Code 2494465 at pXS,3wO=BO$DR(:213132721
DEBUG: Code 2654762 at pXS,3wO=BO$DR(:213132721
DEBUG: Code 0 at Ui!jGgB/A<F%XL.H(]:121273641
DEBUG: Code 0 at Ui!jGgB/A<F%XL.H(]:121274699
Title #1 (2:51:12) was skipped due to navigation error
Cells 7-7 were removed from title end
Title #2 was added (6 cell(s), 0:43:14)
Title #3 was added (6 cell(s), 0:40:34)
Cells 1-1 were removed from title start
Title #4 declared length is 0:39:05 while its real length is 0:20:04 - assuming fake title
DEBUG: Code 2654762 at Ui!jGgB/A<F%XL.H(]:29400094
DEBUG: Code 0 at Ui!jGgB/A<F%XL.H(]:213115747
Title #5 was added (5 cell(s), 0:40:15)
Title #11 was added (1 cell(s), 0:00:21)
Title #11/1 was added (1 cell(s), 0:00:11)
Title #12 has length of 1 seconds which is less than minimum title length of 5 seconds and was therefore skipped
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '14336'
DEBUG: Code 100864256 at T*66mI"9R%2H!-6CI':213131502
DEBUG: Code 1 at ~nSEtLvc8xH_lc"$:121262578
DEBUG: Code 0 at n0I*~P>e<MxG\iV:213138494
DEBUG: Code 0 at "NLX^`Ns%Dx_%F:29398185
Encountered 121 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
Saving 4 titles into directory E:/Users/Jamison/Video/MakeMKV Output/Gilmore Girls/Season 5/D1
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_02_1.VOB' at offset '110592'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '110592'
DEBUG: Code 3221225628 at T*66mI"9R%2H!-6CI':213131502
DEBUG: Code 0 at %K{3+D<I-p.W2g)K$P73:29395471
DEBUG: Code 0 at Z|}2O^LgDo#G1R{T{y :29393562
DEBUG: Code 0 at %K{3+D<I-p.W2g)K$P73:213131157
DEBUG: Code 0 at %K{3+D<I-p.W2g)K$P73:121262647
DEBUG: Code 54 at %K{3+D<I-p.W2g)K$P73:121261773
DEBUG: Code 0 at "I0?2XJ_UPV9?r3<b,B}qq:121263751
DEBUG: Code 0 at 5#w%HEc@g}P<=`%X^J>Av:213137068
DEBUG: Code 0 at #U-CH*_@vi7X5z=Cjizv:29394022
DEBUG: Code 0 at #U-CH*_@vi7X5z=Cjizv:121266764
DEBUG: Code 0 at 5#w%HEc@g}P<=`%X^J>Av:29400462
DEBUG: Code 0 at 5#w%HEc@g}P<=`%X^J>Av:213136700
DEBUG: Code 0 at F(;hmsvFkL!;Ut_P^=::29394482
DEBUG: Code 0 at F(;hmsvFkL!;Ut_P^=::121264740
DEBUG: Code 0 at F(;hmsvFkL!;Ut_P^=::29396138
DEBUG: Code 0 at F(;hmsvFkL!;Ut_P^=::213134906
DEBUG: Code 0 at rW7LRhJZY*VT:"D7:213130904
DEBUG: Code 0 at rW7LRhJZY*VT:"D7:213130582
DEBUG: Code 0 at ~oh{+ReP=Y.St+[i$j:121269731
DEBUG: Code 0 at ~oh{+ReP=Y.St+[i$j:29401819
Failed to save title 2 to file E:/Users/Jamison/Video/MakeMKV Output/Gilmore Girls/Season 5/D1/GILMORE GIRLS SEASON 5 DISC 1_t02.mkv
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_02_1.VOB' at offset '2625536'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '2625536'
DEBUG: Code 1282 at %K{3+D<I-p.W2g)K$P73:121261773
Failed to save title 3 to file E:/Users/username/Video/MakeMKV Output/Gilmore Girls/Season 5/D1/GILMORE GIRLS SEASON 5 DISC 1_t03.mkv
Encountered 53 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
2 titles saved, 2 failed
Debug logging enabled, log will be saved as C:\Users\username/MakeMKV_log_1.txt
Open DVD manually : "1 2 3 4 5"
DEBUG: Code 1932806 at pXS,3wO=BO$DR(:29396184
Title #1 (2:54:14) was skipped due to navigation error
Title #2 was added (6 cell(s), 0:43:46)
Title #3 was added (6 cell(s), 0:43:46)
Title #4 (0:42:55) was skipped due to navigation error
Title #5 was added (6 cell(s), 0:43:41)
pneumatic
Re: Trouble With Gilmore Girls
#2 Post by pneumatic » Wed Dec 13, 2023 4:30 pm
All I can do is share the steps I go through when encountering trouble discs
1. Try cleaning the disc with isopropyl alcohol and dry thoroughly. One time this didn't work for me so I put the disc back in its case, came back a few days later and magically it reads. Inspect the disc surface under a LED flashlight too - in one case I can see there are some weird ripples under the surface when shining the light at certain angles. So even though it looks good to the naked eye, it may not be.
2. Try different drives. I would recommend having at least 2 different drives, but 3 or 4 is better... I have 4 at my disposal currently. In one case only the 4th drive could read the disc, and that was a very cheap internal laptop drive which I was expecting to perform worse.
3. Try dumping the entire disc to an .ISO image file with DVD Decrypter, then open the .ISO file in MakeMKV.
4. Try DVD Decrypter in IFO mode to extract titles. This will give you .vob files instead of .mkv files, but media players should be able to play .vob files too. It's just a different container format after all.
5. Try DVD Shrink to do the same as 4. Use its Re-Author mode (make sure to select "no compression" as that will transcode the video to a lower bitrate). It's basically the same as MakeMKV except extracts to .vob files instead of .mkv.
If anyone else has more suggestions please add them below as I know how frustrating it is to be missing an episode or two from a series, it just really ruins the mood.
fradster
#3 Post by fradster » Sat Dec 16, 2023 5:05 pm
Thanks pneumatic - I'll have to try some of these things and report back.
I haven't tried any of your methods before. Only washing with mild soap and then a Maxell disc scratch repair kit (which I feel like I just made it worse LOL).
#4 Post by dcoke22 » Sat Dec 16, 2023 6:53 pm
I've never tried it, so can't vouch for its effectiveness, but I've seen people say positive things about Gel Gloss.
https://forum.makemkv.com/forum/viewtopic.php?p=106920#p106920
Once you try all of the very reasonable things pneumatic has suggested and if none of them work, then, maybe you would be willing to risk a 'cleaning' with Gel Gloss.
fradster
#5 Post by fradster » Sat Dec 23, 2023 3:49 am
I tried it all on those poor discs to no avail.
Caved and bought a new copy when I saw it on sale.
Well... I didn't try the gel gloss b/c I just saw it after I came back to reply with my admission of defeat ha. Next time!
