Possible use of multicore CPUs?
dom61
#1 Post by dom61 » Fri Jul 15, 2011 9:18 am
Making the conversion of multiple sessions simultaneously.
I noticed it has been used almost exclusively to the RAM
and non-core CPU.
You could set the program to make better use of processor cores?
THANKS
Ugoos AM6B Plus | Remote control G20S PRO Plus | Splitter HDMI HDFury AVR-KEY | Display LG 65B6V | Cables HDMI KabelDirekt Pro series | Audio processor Yamaha RX-V775 | Rotel RMB-1075 | Storage Qnap Ts-431K +TL-D800C |
My PC Ryzen 7950X
BlackDragon24
Re: Possible use of multicore CPUs?
#2 Post by BlackDragon24 » Fri Jul 15, 2011 8:05 pm
dom61 wrote:Making the conversion of multiple sessions simultaneously.
and non-core CPU.
THANKS
The rate limiting step with makemkv is the speed of the drive, or more technically, how fast a certain dvd/blu-ray drive can communicate through the motherboard to the hard drive. Adding cpu cycles will not copy it faster to the hard drive.
Smithcraft
#3 Post by Smithcraft » Sat Jul 16, 2011 7:18 am
Lets get MakeMKV rewritten in OpenGL or CUDA so it can use all the cores available on our graphics cards! :wink:
SC
#4 Post by mike admin » Sat Jul 16, 2011 11:40 am
MakeMKV already uses multiple cores - you can see for yourself, no single core is overloaded. MakeMKV also uses AES-NI instructions when available, decrypting with hardware. In your case you're limited by the drive speed.
