Weird issue with guitar lesson DVD
george14215
#1 Post by george14215 » Fri Dec 15, 2023 12:20 am
This is not a critical issue, but I thought I'd report it...
My DVD plays on multiple drives. But MakeMKV is unable to either make a backup or make an MKV. It just churns away with the remaining time growing and growing into double digit hours.
On my mac was able to make a DMG image via Disc Utility then convert it to ISO.
When using MakeMKV to open the IFO file on the mounted DMG image or open the ISO, I get this error
Complex multiplex encountered - 4 cells and 1750 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #1 (1:39:16) was skipped due to navigation error
The converted ISO plays fine via DVD Player or via Infuse on Apple TV accessing the ISO remotely via SMB.So I'm pretty sure the disc and the resulting ISO are fine.
Re: Weird issue with guitar lesson DVD
#2 Post by dcoke22 » Fri Dec 15, 2023 4:42 am
There are different opening modes for DVDs. What happens if you try a different opening mode?
george14215
#3 Post by george14215 » Fri Dec 15, 2023 6:01 pm
CellWalk
CellTrim
CellFull
Note, while Infuse can open the ISO file and play it, VLC cannot. All my physical players can play it. I can provide you with any file you want if this something the developers want to look at. Again, it's not an urgent issue for me. I just really like this tool and reporting what appears to be a bug.
edit: added clarification to "players"
