Post your blu-ray drive and speeds with makekv
BlackDragon24
Post by BlackDragon24 »
Hey all
Wasn't sure if we had one of these and if we do please forgive me. I'd like to compile a list of Blu-ray drives and the speeds that are generally seen when using makemkv, so that we might all be able to make the best choices when it comes to purchasing our hardware.
I'll start:
Drive: Pioneer BDR-206 Internal SATA
Speed: Maximum mkv writing speed from blu-ray that I've seen with this drive is 4.1X, which works out to about 17 mb/s. Most BD's burn down at speed of 2.0X-3.0X.
crowfax
Re: Post your blu-ray drive and speeds with makekv
Post by crowfax »
Plextor PX-B310U - External USB drive with own power supply.
Ripping speed between 2.0x and 5.0x (assuming the disc isn't damaged, I've seen it drop down to 0.8x).
reebok
Post by reebok »
Samsung SH-B123L (firmware SB04) internal SATA. It's rated 12x read and I max out at 6.1x from what I've seen. I'd say it averages around 5-5.5x.
hahafunny
Post by hahafunny »
Manufacturer: MATSHITA
Product: BD-MLT UJ230AS
Revision: 1.11
usb with 2nd usb cable for power... 1.5 - 1.6 on blu ray discs....
AppleTV 2
ai3rocks57
Post by ai3rocks57 »
Asus BR-04B2T
Rated at 4x read.
Realistically get around 2.8-3.0x
priitv8
Post by priitv8 »
LG BH10LS30, external USB enclosure (jMicron USB-SATA bridge), MakeMKV 1.6.10:
First result (stock firmware 1.00):
Max ripping speed: 12.2 Mb/s [2.8X]
After flashing the riplock-free 1.00 firmware:
Max ripping speed: 28 Mb/s [6X]
Averaged: 148 minute movie came off the disc in 30 minutes, yielding about 4X ripspeed in average.
testmetest
Post by testmetest »
Lite On IHBS112-29
Stock firmware
No Country For Old Men
122 minutes runtime
LPCM with English subtitles
Ripped in 18 minutes, 49 seconds [5.1x]
Max I recall seeing is spooling up to 7.4x before slowly settling around 6-something.
It generally rips blurays in 20 minutes (primary video track, DTS-MA/TrueHD/LPCM, English subtitles).
It's definitely is worth the upgrade for $99. I used an LG before and it was painfully slow.
KYThrill
Post by KYThrill »
Asus BC-12B1ST
1.0 Firmware
4-5X speeds on dual layer discs in the sweet spot
7-8X on single layer discs in the sweet spot
Max that I've seen is 9.2X.
Overall, a nice, nearly silent BD drive (and no AACS Bus Encryption)
