deadchip12
Post by deadchip12 » Mon Dec 11, 2023 12:01 am
RESET_9999 wrote: Sun Dec 10, 2023 12:55 pm pretty much but I just found something concerning about our beloved x700/x800 with low nits real content Five.Nights.at.Freddys.2023 : https://slow.pics/c/R0A9O244
according to the original brightness and metadata plot(L1 L2), only the Shield makes sense here.
Sorry could you explain what the screenshot indicates?
And do the current issues with the x700/x800 only happen with dolby vision files but not dolby vision discs?
Post by RESET_9999 » Mon Dec 11, 2023 2:42 am
deadchip12 wrote: Mon Dec 11, 2023 12:01 am Sorry could you explain what the screenshot indicates?
Reference: original HDR frame is 92 nits , Edid is LG C2 (896nits). L2 trims is a positive lift (brighten), L1 is 100nits
x700 L1 + L2 original is 82nits (darker than HDR10, doesn't make sense)
x700 L1 only is 66nits (much darker than HDR10, doesn't make sense)
ATV L1 + L2 original is 93nits (trims bring the brightness to the original level)
ATV L1 only is 76nits (darker than HDR10, doesn't make sense)
Shield L1 + L2 original is 114nits (expected brightness for this type of L2 lift)
Shield L1 only is 94nits (same as original brightness. expected for a 100nits L1 on a 896nits TV)
Only the Shield seems logical here.
plots (shot is around frame 1200 IIRC)
Image Image
HotFudge
Post by HotFudge » Mon Dec 11, 2023 7:43 am
RESET_9999 wrote: Fri Dec 08, 2023 3:31 pm
crosis wrote: Fri Dec 08, 2023 4:50 am Preferably a scripted process as I've heard that one is available
No idea about handbrake but the script in my signature can bake FEL to P8. Workflow 8-6-1 but it requires an nvidia GPU.
it can also encode P5 to P8, HLG to HDR10 or P8 to P8
When will 1.9.8.6 be released? Github latest version is 1.9.8.5
Post by RESET_9999 » Mon Dec 11, 2023 11:07 am
HotFudge wrote: Mon Dec 11, 2023 7:43 am When will 1.9.8.6 be released? Github latest version is 1.9.8.5
idk, I haven't made enough changes yet.
- Added PGS/SUP to srt (auto OCR) (line 80 default = NO)
- Added an option to compare SDR in an HDR container for workflow 7-2 (line 132 default=NO)
- Added an option to force mp4box_2 (line 16 default=NO)
- Tools: Subtitle.edit must be added in the tools folder. (only needed if line 80 = YES)
- Tools: mkvtoolnix files must be updated to the latest version.
Post by RESET_9999 » Mon Dec 11, 2023 11:11 am
Windows Movies and TV app support Level 5 surprisingly (and also cmv4.0). Only HDMI device to support L5 so far.
crosis
Post by crosis » Mon Dec 11, 2023 4:48 pm
RESET_9999 wrote: Mon Dec 11, 2023 11:07 am
I wanted to thank you for the help with your script. I have adjusted the encoder settings and arrived at bitrates very close to what I was getting in Handbrake. On the next update, would you be able to add an option in your workflow to choose a subtitle track to burn into the video? I always burn any forced subtitles so that I don't need to mess with OCR-ing and organizing multiple subtitle files. I am currently looking into AVISynth plugin "SupTitle" to manually add to the avs script before it kicks it over to X265.
HotFudge
Post by HotFudge » Mon Dec 11, 2023 5:31 pm
Hi Reset
I have HDR10+ metadata but it is 24 frames ahead of my UHD mkv.
Is it possible to resync and inject this with the DoVi scripts ?
thirdmoon
Post by thirdmoon » Tue Dec 12, 2023 2:18 am
RESET_9999 wrote: Mon Dec 11, 2023 11:11 am Windows Movies and TV app support Level 5 surprisingly (and also cmv4.0). Only HDMI device to support L5 so far.
If I have a P5 DV in MKV and a HDR monitor,
1. Which workflow should I use to make it work with windows app?
2. Do I have to turn on HDR in the windows settings too?
3. Any other requirements?
Post by RESET_9999 » Tue Dec 12, 2023 3:17 am
crosis wrote: Mon Dec 11, 2023 4:48 pm On the next update, would you be able to add an option in your workflow to choose a subtitle track to burn into the video?
Maybe, not sure. I'm not a fan of hardcoded subs.
HotFudge wrote: Mon Dec 11, 2023 5:31 pm I have HDR10+ metadata but it is 24 frames ahead of my UHD mkv.
Nop, my script cannot resync hdr10+.
thirdmoon wrote: Tue Dec 12, 2023 2:18 am If I have a P5 DV in MKV and a HDR monitor,
1- set mp4_version=NEW and workflow 5
2- yes
3- HEVC and dolby vision extension.
https://apps.microsoft.com/store/detail ... MZLZ57R3T7
https://apps.microsoft.com/store/detail ... n-us&gl=US
deadchip12
Post by deadchip12 » Tue Dec 12, 2023 3:59 am
EDIT: Nevermind. I think it's because the Dovi Scripts files were not placed inside a root folder of the hard drive.
I'm running workflow 4-3 to add silent AC3 core to DV MKV file. Not sure why it says: "The system cannot find the file E:\Films\FILM". My DV MKV file path is: E:\Films\[movie name]\backup, while the DoVi_Scripts_TS. bat file and tools folder are in E:\Films\FILM MUXER\DoVi_Scripts
Post by RESET_9999 » Tue Dec 12, 2023 4:24 am
deadchip12 wrote: Tue Dec 12, 2023 3:59 am EDIT: Nevermind. I think it's because the Dovi Scripts files were not placed inside a root folder of the hard drive.
the script folder doesn't have to be at the root drive but it doesn't like when you put it in a path with space or special characters.
so you just had to remove the space in E:\Films\FILM MUXER\DoVi_Scripts
deadchip12
Post by deadchip12 » Tue Dec 12, 2023 9:06 am
RESET_9999 wrote: Tue Dec 12, 2023 4:24 am
Ah makes sense. Thank you :D
HotFudge
Post by HotFudge » Wed Dec 13, 2023 12:57 pm
Hi
Getting confused.
For injecting Web-DL into UHD.
UHD frame 5038 matches WEB frame 5022.
So when using NEGATIVE 16 delay the screenshots match using 7 - 2.
When I then inject the rpu into my UHD to resync do I also enter POSITIVE 16 to resync the RPU using 1-1?
Post by RESET_9999 » Wed Dec 13, 2023 1:08 pm
HotFudge wrote: Wed Dec 13, 2023 12:57 pm Hi
Getting confused.
in 1-1 you want to sync the WEB to the BD, yes you have to duplicate 16 frames so it's positive 16
in 7-2 it depends of which video you input first
But you should always double check your final hybrid with 2-4(full) or 2-5(quick)
HotFudge
Post by HotFudge » Wed Dec 13, 2023 1:57 pm
RESET_9999 wrote: Wed Dec 13, 2023 1:08 pm
Getting confused.
Cheers Mates for clarifying
