I'm trying to flash the following:
-D: HL-DT-ST_BD-RE__WH14NS40_1.05_212005061444_KLXN9G85653
I tried both the following bins but both produced a error code "0x82052603":
-DE_LG_WH14NS40-NS50_1.02
-DE_LG_WH16NS40-NS50_1.02
Am I not using the right bin file? I don't see another option in the "All you need firmware Pack".
Error When Flashing WH14NS40
Re: Error When Flashing WH14NS40
yeah both wrong would help if you followed the guide is says flash WH16NS60 1.02 see belowsgtstrife wrote: Mon Dec 11, 2023 6:55 pm I'm trying to flash the following:
You are correct. Sorry, this was my first thread and it had to be reviewed or I would have deleted it shortly after posting it as I found my solution. I did try searching for a solution before writing it as well. Thank you!
