Caffeine
#2041 Post by Caffeine » Mon Dec 11, 2023 11:20 pm
Hi. There appear to be very few Vantec NST-510S3-BK left in the wild. I've not seen mention of a replacement. Would anyone have recommendations for a 9.5mm case (for a BU40N) from the usual places (Amazon, eBay, etc.)? Aware of preferred sellers on here. Thanks.
#2042 Post by Billycar11 » Tue Dec 12, 2023 12:59 am
Caffeine wrote: Mon Dec 11, 2023 11:20 pm Hi. There appear to be very few Vantec NST-510S3-BK left in the wild. I've not seen mention of a replacement. Would anyone have recommendations for a 9.5mm case (for a BU40N) from the usual places (Amazon, eBay, etc.)? Aware of preferred sellers on here. Thanks.
i think this one just come with a spacer says 12.7 or 9.5mm https://www.amazon.com/dp/B01974P50O/ref=emc_b_5_t?th=1
strkilla89
#2043 Post by strkilla89 » Thu Dec 14, 2023 1:51 am
Hi all new to this. I have a July 2012 WH14NS40 Rom ver 1.00. I also ordered a new WH14NS40 off of amazon as this drive is listed as being too old for the tool. I just wanted to confirm that this drive is not compatible with 4k blurays at all. I did try one bluray in it and it failed to read and mount in windows and did not appear in makemkv.
skidog72
#2044 Post by skidog72 » Thu Dec 14, 2023 2:28 am
Guess I should have came and looked at the MakeMKV forums first but I figured the manufacturer should know what they're doing. :shock: So have the LG model WH16NS40 ROM ver 1.04 svc code: NS50 Manufacture date 3/2020. I attempted to update the firmware to 1.05 using the official LG update tool and of course it froze like halfway thru installation. Upon reboot now my drive appears to be in BOOT mode according to MakeMKV. Eject button doesn't respond now. Any suggestions on how to get it back out of BOOT mode?
thanks!
#2045 Post by MartyMcNuts » Thu Dec 14, 2023 3:07 am
strkilla89 wrote: Thu Dec 14, 2023 1:51 am Hi all new to this. I have a July 2012 WH14NS40 Rom ver 1.00. I also ordered a new WH14NS40 off of amazon as this drive is listed as being too old for the tool. I just wanted to confirm that this drive is not compatible with 4k blurays at all. I did try one bluray in it and it failed to read and mount in windows and did not appear in makemkv.
No, too old.
Neccros
#2046 Post by Neccros » Thu Dec 14, 2023 3:32 pm
So new to all this and head is spinning.
So I have a LG WH16NS40 v1.03 mfg 3/6/2018 and trying to figure out if I can just flash it or if it needs to be flashed to something else first... From what I read it appears I need to go to 1.2 first then re flash it?? Feel like I am on a episode of the Californians! LOL
Appreciate any help!
#2047 Post by d00zah » Thu Dec 14, 2023 5:19 pm
Neccros wrote: Thu Dec 14, 2023 3:32 pm So new to all this and head is spinning.
WH16NS40 on any Firmware directly to > WH16NS60 1.02MK
filename = HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
WH16NS60 1.02MK is a patched version which, among other things, resolves the "sleep bug".
If running Windows, use the SDFtool Flasher... download & follow instructions in 1st post of that topic.
Neccros
#2048 Post by Neccros » Thu Dec 14, 2023 5:26 pm
So just need to get it on that 1.02 and I should be golden? Sweet! Will try after work and see how it goes...
Caffeine
#2049 Post by Caffeine » Fri Dec 15, 2023 3:20 am
Billycar11 wrote: Tue Dec 12, 2023 12:59 am i think this one just come with a spacer says 12.7 or 9.5mm https://www.amazon.com/dp/B01974P50O/ref=emc_b_5_t?th=1
Thanks. Spacer? Page has 4 models referred - I see it mention 520S3 for 12.7mm and 510S3 for 9.5mm. Should point out I'm not in the US of A.
Stevelois
#2050 Post by Stevelois » Fri Dec 15, 2023 5:37 pm
I'm from Montreal, Canada.
I think my LG WH16NS60 is defect so I need to purchase another. Still, it isn't available anymore for repurchase on Amazon.
After reading the OP, Pioneer are the top UHD drives to get. BUT it is note : The recommended drives are Pioneer's they are much better than Asus and LG but sadly they cant be flashed currently you will have to buy ones with old firmware from sellers for now.
The thing is that all local stores don't have any of the suggested drives in stock. Best Buy, Bureau En gros (Stapples), La source, Wallmart, etc. So I must buy online like Amazon.ca, CanadaComputers.ca, Newegg.ca, etc. Even then, a very few models are still available.
Brief, I'm extremely limited. Only one I can purchase on Amazon is Pioneer BDR-S13UBK and cost more than 300$ with taxes while my LG cost me 100$ in 2022! Furthermore, I have no idea what is the firmware version until I'll have the drive in my hands. It is super expensive and I must say, I don't know what to do :|
#2051 Post by d00zah » Fri Dec 15, 2023 5:47 pm
There are "local" sellers here, including one in Canada who might be able to help you out. Others are just south of the border, if he is unable to provide what you're looking for? They all offer email addresses. Can't hurt to send out some inquiries.
Stevelois
#2052 Post by Stevelois » Fri Dec 15, 2023 6:01 pm
I wasn't aware of that place, THX. Will check it out :D
Eggman
#2053 Post by Eggman » Mon Dec 18, 2023 3:00 pm
Do you think the new detachable PlayStation 5 UHD Drive will become relevant for flashing, ripping etc? It is widely available and will have a large install base. It is also sold separately at an affordable price.
#2054 Post by Billycar11 » Mon Dec 18, 2023 6:15 pm
Eggman wrote: Mon Dec 18, 2023 3:00 pm Do you think the new detachable PlayStation 5 UHD Drive will become relevant for flashing, ripping etc? It is widely available and will have a large install base. It is also sold separately at an affordable price.
No
Eggman
#2055 Post by Eggman » Tue Dec 19, 2023 11:23 am
Billycar11 wrote: Mon Dec 18, 2023 6:15 pm No
K thnx
