No Highway in the Sky (1951) DVD
ADeMeneghi
Post by ADeMeneghi » Sat Dec 09, 2023 10:05 pm
I tried few DVD (No Highway in the Sky - 1951), they are all clean and no major damage on the surface. Tried different DVD readers too. An was not able to convert it. The MakeMKV (version 1.17.5), when readin the DVD stop on the VOBU 49721, and is not able to complete the disc reading ? I use the MacOS MakeMKV.
Does anyone had the same problem or a suggestion to resolve it
Re: No Highway in the Sky (1951) DVD
Post by Woodstock » Sun Dec 10, 2023 12:35 am
Multiple disks AND multiple drives stopping at the same location reminds me of a disk I have... I could not get it to read a particular track on multiple drives. Replaced the disk. Same spot has a failure. Replaced the disk 3 more times, including multiple rentals from Netflix. Always died at the same location.
Eventually I dug out a DVD-only drive... a Sony from the turn of (this) century. Turned up the retry count on MakeMKV. Eventually, it was able to read that track. It was a defect in the disk that was present in 5 different copies.
That's one possibility. Read retry count is on the Preferences->IO menu. Default is 10. Don't get ridiculous with it... 100 is not going to help, for example.
ADeMeneghi
Post by ADeMeneghi » Sun Dec 10, 2023 1:55 am
Thanks, I changed to 25 but still stopped on the same VOBU 49721
MakeMKV log:
MakeMKV v1.17.5 darwin(arm64-release) started
Optical drive "BD-ROM SanDisk SanDisk Cruzer 8.02" opened in OS access mode.
It's highly recommended to install DASPI kernel extension to improve performance.
Optical drive "BD-RE PIONEER BD-RW BDR-XD08U 1.02 BLDL001589UCd" opened in OS access mode.
udf: udf_get_node: bad allocation extension size in udf_node
Calculated BUP offset for VTS #0 does not match one in IFO header.
Calculated BUP offset for VTS #3 does not match one in IFO header.
Calculated BUP offset for VTS #4 does not match one in IFO header.
ADeMeneghi
Post by ADeMeneghi » Sun Dec 10, 2023 7:54 am
Was interesting I move the DVD player to a Windows 11 PC Computer and was able to copy the DVD without a problem !!
MakeMKV v1.17.5 win(x64-release) started
Title #1 has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Can't locate a cell for VTS 3 TTN 1 PGCN 0 PGN 0
Cells 12-12 were removed from title end
Title #3 was added (11 cell(s), 1:37:57)
Title #4 was added (2 cell(s), 0:02:08)
Title #4 with special attributes was skipped
Title #5 with special attributes was skipped
