Converting DTS-HD MA or ripping the same as LPCM
Re: Converting DTS-HD MA or ripping the same as LPCM
mudstuff wrote: Thu Dec 07, 2023 3:44 pm Hi, I'd love some help on this if possible. I copied the code you kindly provided, saved as xml and named it LPCM.xml in the make mkv data folder. No new profile appears though, could you help?
My file is named lcpmtest.mmcp.xml.
mudstuff
Post by mudstuff »
Thank you, I'm not sure if it was the renaming or the fact I initially did it with notepad and used Notepad++ second time around but it's now showing in the profile list.
iduda66
Re: CONVERTING FLAC 5.1 TO DTS-HD MASTER 5.1
Post by iduda66 »
i found a free program which converts flac 5.1 /wav 5.1 to dts-hd master 5.1 when i did the conversion i get output file sizes 5to6 times larger than the imput files I asked ai if the files i got were dts-hd master files and it confirmed they most probably are THE PROGRAM I AM TALKING ABOUT IS AIMP V5.2 BUILD 2366 (02/03/2022) CHECK IT OUT PLEASE IT IS GREAT AND IS FREE
