WDTV don't play MKV's muxed from the following versions:
1.6.9
1.6.10
1.6.12
I think, its a known issue since 1.6.9
WDTV Live don't play MKV's muxed since 1.6.8
Re: WDTV Live don't play MKV's muxed since 1.6.8
I have a WD TV Live and the MKV's made with 1.6.12 are working fine. Is it all movies, or only some movies?
It's all movies.crowfax wrote:I have a WD TV Live and the MKV's made with 1.6.12 are working fine. Is it all movies, or only some movies?
Maybe it depends on the Version of the WDTV-Device, its the newest.
Yes, of course, i have the newest Version!crowfax wrote:Are you running the latest firmware?
http://www.wdc.com/wdproducts/updates/? ... fwdtv_live
So, what do you think:
I mux the same movies (Blu Rays) in the same way with 1.6.8 and 1.6.12.
The Movies with 1.6.8 are played by the WDTV, the 1.6.12 not. So, what do you think where the problem is ?
Give me some of the titles of discs that don't work for you. I'll test them myself.
