M3GAN UHD - Dump File
Arndrell
#1 Post by Arndrell » Wed Nov 29, 2023 7:51 pm
Evening,
M3GAN dump file sent
MKB20_v77_M3GAN_AF42
Obsessive compulsive ripper and collector since finding Make MKV!
Converting nearly 1,200 Blu Rays and UHD in 1:1 format to a Plex library serviced by Infuse.
Chris01992
Re: M3GAN UHD - Dump File
#2 Post by Chris01992 » Thu Nov 30, 2023 12:17 pm
I've sent this one in a couple of time but no joy yet...
viewtopic.php?f=12&t=32284
Maybe there's an issue with this disc?
Arndrell
#3 Post by Arndrell » Fri Dec 01, 2023 10:41 pm
I assume Mike is a busy man, took around a week for the Nun 2 to get fixed!
Tried again tonight and it failed again.
Arndrell
#4 Post by Arndrell » Thu Dec 07, 2023 9:01 pm
Still failing, has anybody managed to rip this title yet?
Chris01992
#5 Post by Chris01992 » Fri Dec 08, 2023 12:46 pm
Nope - still getting volume key unknown error message on this one.
RichL101
#6 Post by RichL101 » Fri Dec 08, 2023 2:42 pm
If it helps I used AnyDVD in the end to get this 4k version ripped.
Arndrell
#7 Post by Arndrell » Sat Dec 16, 2023 7:25 pm
Still failing, I've never had a disk take this long to be unlocked previously after sending a dump file through..
Don't get me wrong, I can assume some work needs doing by people/persons and therefore I'm not trying to moan or be a dick - is there anything I can do to help or speed this process up?
Arndrell
#8 Post by Arndrell » Fri Dec 22, 2023 10:59 pm
All,
Is this defiantly a "key" issue?
Using LibreDrive mode (v01.0 id=F1ED73020654)
Saved AACS dump file as C:\Users\jtaylor/.MakeMKV/MKB20_v77_M3GAN_AF42.tgz
DEBUG: Code 0 at *>y@ce*3@Z%S'=:>:213132721
DEBUG: Code 0 at *>y@ce*3@Z%S'=:>:213131341
Reason I ask is that I posted/emailed two other (different) dump files less than 48 hrs ago and both have now decoded, whereas this disc is still failing weeks later?
Thank you in advance,
Arndrell
#9 Post by Arndrell » Sat Dec 30, 2023 12:17 pm
Saved AACS dump file as C:\Users\ /.MakeMKV/MKB20_v77_M3GAN_AF42.tgz
DEBUG: Code 0 at *>y@ce*3@Z%S'=:>:121263084
Emailed twice to SVQ@makemkv.com - 3.3mb
Manufacturer: PIONEER
Product: BD-RW BDR-S12U
Revision: 1.02
Serial number: ALDL005994WL
Firmware date: 2022-03-07
Highest AACS version: 78
Drive platform: RS8F01
Firmware version: 1.02/ID43
Right I have now done an encrypted backup of this disk (stored on my external SSD) to make it easier to periodically check to see if this disc has been unlocked - which it still hasn't..
There must be something specific with this disk and its bump file that is causing such a delay, the other dumps that I have sent have been unlock in the usual 2-3 day time frame?
I know that a lot of forum members get bored to tears answering the same newb questions, over and over but what am I missing here?
I have done some reading on AACS2.1, which in fairness I'm still not fully grasping - is this disc another Zombieland issue, should I just return it and get another copy/import copy?
If I'm being dense please feel free to flame me, I won't take offence - it's just getting under my craw now as to why there is such an issue with this title.
Cheers J
#10 Post by Coopervid » Sat Dec 30, 2023 12:24 pm
Arndrell
#11 Post by Arndrell » Sat Dec 30, 2023 12:57 pm
Coopervid wrote: Sat Dec 30, 2023 12:24 pm viewtopic.php?f=12&t=32784
Thanks for the response Coopervid - just trying this now and I will report back :wink:
Arndrell
#12 Post by Arndrell » Sat Dec 30, 2023 1:17 pm
@Coopervid
Okay, no dice.. Just want to make sure I've actually doing what I need to do correctly before giving up?
Found the FindVuk 1.72 download - https://www.videohelp.com/software/FindVUK
Downloaded it and then ran "FindVUK - Synchronize" - pop up box quickly flashes up and then disappears - too fast to see what if anything it says
Checking C:/user/user/appdata/roaming - I cannot find a folder: AACS or the keydb.cfg file motioned (unhidden all folder/files)
Arndrell
#13 Post by Arndrell » Sat Dec 30, 2023 3:41 pm
After much messing about, I managed to follow your instructions and get the AACS file to load into AppData, copied this to .MakeMkv re-ran the "Backup" of M3GAN and it has failed again..
I will try the physical disc later tonight but I don't hold out any hope of it working. All said I would like to thank you @Coopervid for trying to assist me with this today.
#14 Post by Coopervid » Sat Dec 30, 2023 5:18 pm
One UHD version is supported. Maybe this is not.
Arndrell
#15 Post by Arndrell » Sun Dec 31, 2023 9:45 pm
With the help of another forum member we have come to the conclusion that this disc isn’t anything special and the Key is in the dump file that I have already sent to the SVQ email address.
For whatever reason this just hasn’t been updated in the database yet, so it’s a waiting game for the required update to be completed.
I will send the file as a One Drive link just in case it’s not getting through for some reason.
As a side note, I have also tried AnyDVD as suggested earlier and it also failed there as well.
