Episode order
lexed
Episode order
#1 Post by lexed » Fri Dec 08, 2023 7:05 am
This might be a dumb question. For TV shows you rip that you’ve never seen before, is there a way to determine which file is which episode? I hate having to comb through episodes and potentially spoil myself before watching just to find the proper order.
Re: Episode order
#2 Post by Woodstock » Fri Dec 08, 2023 1:51 pm
Looking at the raw data, "Maybe".
Usually, there will be order tot he file names on the disk itself, but MakeMKV changes the file names based on the order they're found in the directory, rather than "order of name on disk".
Prior to ripping, you can scroll through the titles in the left window, and view the "Source file name" field on the right side, under "Title information". That USUALLY shows the name on the disk, rather than the ORDER on the disk.
