Nightmare Before Christmas UHD Dump
Mark Alexis
Re: Nightmare Before Christmas UHD Dump
Post by Mark Alexis » Mon Aug 28, 2023 6:29 pm
I'm ripping mine as we speak. The other day it wasn't working yet.
MovieMan88
Post by MovieMan88 » Mon Aug 28, 2023 8:06 pm
Not sure if it matters, but I purchased the Steelbook version. I cant imagine the mastering would be different between the Steelbook and the regular 4k disc.
As of this time, the software has downloaded the latest database and I can now rip the 4k disc to mkv.
demon
Post by demon » Tue Aug 29, 2023 3:02 pm
Works for me now as well. Thanks Mike!
allaboutsound
Post by allaboutsound » Fri Dec 08, 2023 2:31 am
I am experiencing this issue as well, any tips on what I can do? Seems like it's impossible to get this disc to rip.
OS device name: G:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: [redacted]
Highest AACS version: 77
Firmware version: 1.02
Disc Information
Label: THE_NIGHTMARE_BEFORE_CHRISTMAS
Timestamp: 2023-06-28 19:43:31
Protection: AACS2.0/C v77
Data capacity: 57.19 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Post by MartyMcNuts » Fri Dec 08, 2023 5:23 am
allaboutsound wrote: Fri Dec 08, 2023 2:31 am I am experiencing this issue as well, any tips on what I can do? Seems like it's impossible to get this disc to rip.
OS device name: G:
Revision: 1.02
Disc Information
Number of layers: 2
Experiencing what issue? It looks like everyone can rip it now. If you are getting errors, show them and we may be able to help.
allaboutsound
Post by allaboutsound » Fri Dec 08, 2023 7:40 pm
I think it may just be a faulty disc. I couldn't burn it from MakeMKV, DVDFab, play it from VLC or my PS5. I am going to return it and get another.
ccateni
Post by ccateni » Sun Dec 17, 2023 4:47 am
I also got the steelbook release, and same issue.
Disc isn't faulty as the disc plays fine in my xbox one s.
The disc is also in the keydb file I put in .makemkv but it still doesn't rip.
The application also doesn't want to update the database in the app despite being allowed online access.
Any fix?
Post by dcoke22 » Sun Dec 17, 2023 7:58 am
ccateni wrote: Sun Dec 17, 2023 4:47 am I also got the steelbook release, and same issue.
Any fix?
Are you getting the "Automatic HK downloading is disabled or failed." message? Some helpful entity in the network between your computer and the domain MakeMKV serves hashed keys from might be blocking your access. hkdata.crabdance.com or hkdata.fairuse.org not found
Post by SamuriHL » Sun Dec 17, 2023 12:09 pm
Also make sure the keydb file is exactly named:
KEYDB.cfg
Note the case.
ccateni
Post by ccateni » Sun Dec 17, 2023 2:51 pm
dcoke22 wrote: Sun Dec 17, 2023 7:58 am
Any fix?
Theres no message at all in terms of the database updating.
ccateni
Post by ccateni » Sun Dec 17, 2023 2:57 pm
SamuriHL wrote: Sun Dec 17, 2023 12:09 pm Also make sure the keydb file is exactly named:
KEYDB.cfg
Note the case.
The title was lowercase, so I made it uppercase and it did nothing. Downloaded the latest version from FindVUK, same error as before.
"The volume key is unknown for this disc - video can't be decrypted
Failed to open disc"
ccateni
Post by ccateni » Sun Dec 17, 2023 3:08 pm
Any fix?
So, I did more research.
Updated the hosts file, did nothing.
Then I decided to disable my VPN.
It worked.
It seems Mullvad (even if you allow the site) is blocking the apps function to go to that site even if you use split tunneling.
Post by SamuriHL » Sun Dec 17, 2023 3:19 pm
KEYDB.cfg
Note the case.
Then whatever key was in there didn't match your disc variant.
