Moved to Mac from Windows. USB drive no longer working
tpicnic05
#1 Post by tpicnic05 » Thu Dec 07, 2023 9:30 pm
I have a flashed LG WP50NB40 NB52. Below are the details from MakeMKV:
Product: BD-RE BP60NB10
Revision: 1.00
Serial number: SIM21LBF84058
Firmware date: 2117-11-21 17:20
Highest AACS version: 77
Firmware version: 1.00
When using this drive on Windows I don't have any issues ripping but on my new MacBook Pro M3 Pro I'm not able to open the disc. Here is the output I get:
MakeMKV v1.17.5 darwin(arm64-release) started
Optical drive "BD-RE HL-DT-ST BD-RE BP60NB10 1.00 SIM21LBF84058d" opened in OS access mode.
Downloading latest SDF to /...
Automatic SDF downloading is disabled or failed.
Using LibreDrive mode (v06.3 id=4ACF8047C3AC)
Downloading latest HK to / ...
Saved AACS dump file as Library/MakeMKV/MKB20_v61_Interstellar_194F.tgz
I tried multiple movies and can't open any of them. Is my drive just not compatible with Mac or do I need to flash it with different firmware?
Re: Moved to Mac from Windows. USB drive no longer working
#2 Post by Woodstock » Thu Dec 07, 2023 11:55 pm
Your Mac can't access the site to download the information on the movie you're trying to rip. Is it on internet?
tpicnic05
#3 Post by tpicnic05 » Mon Dec 11, 2023 1:31 pm
Woodstock wrote: Thu Dec 07, 2023 11:55 pm
Yep, connected to the internet.
#4 Post by Woodstock » Mon Dec 11, 2023 1:59 pm
Then something has disabled or is blocking it from accessing the server to get the key from.
In settings, under General, is Enable Internet access checked? If so, what are you using for DNS servers on that machine? You may have an issue with blocking, because it's saying it can't connect.
tpicnic05
#5 Post by tpicnic05 » Mon Dec 11, 2023 2:44 pm
Woodstock wrote: Mon Dec 11, 2023 1:59 pm Then something has disabled or is blocking it from accessing the server to get the key from.
I'm using 1.1.1.1 1.0.0.1 at my router for DNS and I have enable internet access checked. Does MakeMKV use ports other than 80 and 443? I tried digging for ports that might need to be opened but not seeing anything. This is an M3 Pro MacBook if that matters.
#6 Post by dcoke22 » Mon Dec 11, 2023 4:27 pm
Something might be blocking you from accessing the site that hosts keys.
hkdata.crabdance.com or hkdata.fairuse.org not found
The first few posts are from 2019, but they get more relevant when the posts get to 2023.
tpicnic05
#7 Post by tpicnic05 » Mon Dec 11, 2023 8:53 pm
dcoke22 wrote: Mon Dec 11, 2023 4:27 pm Something might be blocking you from accessing the site that hosts keys.
This helped steer me into the right direction. I didn't modify anything on my router but I did connect to VPN and all looks good now.
Thanks for the help folks!
