Cosmos - D3E5 - Fail To Save
Brand new commercial disc. Disc surface appears free of scratches/smudges/imperfections. Confirmed on two different drives. Log attached.
Re: Cosmos - D3E5 - Fail To Save
I uploaded the log but it did not attach. Trying again.
- Contact:
Yet disc has no structure protection but files are corrupted. It's a bad disc or drive.Chest Rockwell wrote:Brand new commercial disc. Disc surface appears free of scratches/smudges/imperfections. Confirmed on two different drives. Log attached.
004004:0000 The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 2411388928, attempting to work around
For whatever it's worth, I'm having the same issue with the same disc and episode (Cosmos D3E5) on my MacBook Pro:
MakeMKV v1.6.5 darwin(x86-release) started
Optical drive "DVD+R-DL HL-DT-ST DVDRW GS23N SB11" opened in OS access mode.
It's highly recommended to install DASPI kernel extension to improve performance.
Title #0 was added (15 cell(s), 1:00:55)
Title #4 was added (15 cell(s), 1:01:04)
Saving 1 titles into directory /Users/Stubbs/Movies/Cosmos
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 2411390976, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 2411393024, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 2411395072, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 2411401216, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 2411403264, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 2411425792, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 2411427840, attempting to work around
Failed to save title 1 to file /Users/Stubbs/Movies/Cosmos/title01.mkv
All the other discs and episodes worked fine, including Episode 4 on the same disc (D3)
I'll keep an eye on this thread for any ideas. I guess there is some comfort in knowing I'm not alone on this one.
Thanks and Regards,
--Stubbs
Thanks and Regards,
--Stubbs
Can you please elaborate on what you mean? It is not a bad drive because I get the same failure on two different drives and another poster just posted he has the same problem.Yet disc has no structure protection but files are corrupted. It's a bad disc or drive.
Also, the disc plays fine in a regular DVD player. In addition I can rip an ISO with IMGburn with zero read errors. When I use MakeMKV on the ripped ISO I still get the same problem.
I purchased this 7 disc 13 episode set when it was first released in 2002 - and, after two exchanges, was frustrated to discover that although the "Mars" episode played properly on my standalone player, it locked up my computer system part way into the episode.
Eventually, I determined that the disc contained a manufacturing "glitch" (disc mastering error) that only affected it being read by the computer system (Standalone players use UDF1.02 format, while computer systems use ISO9660 format).
If I remember correctly, I had to edit out 1 second of video (Fortunately, the editing was virtually unnoticeable).
Although I would typically not suggest an alternative to MakeMKV, in this unusual instance, I'm sure "mike admin" will forgive me if I suggest you try ripping this particular, unusual problematic disc with "DVDFab" (set to skip unreadable sectors).
Let us know how it goes ;>}
Great series by the way - Very satisfying to see each generation of the grandkids in awe of science FACT for a change, rather than science fiction!
- Contact:
Never.setarip_old wrote:I'm sure "mike admin" will forgive me
![Smile :)](./images/smilies/icon_smile.gif)
You can always change what filesystem is parsed for DVD discs. On Mac start the terminal, type
nano ~/.MakeMKV/settings.conf
fs_ForceIsoForUDF102 = "false"
Is there a way to use this workaround on Windows 7 64-Bit? Thanks.mike admin wrote:Never.setarip_old wrote:I'm sure "mike admin" will forgive me
You can always change what filesystem is parsed for DVD discs. On Mac start the terminal, typeand add the following line to configuration fileCode: Select all
Change to "true" for default behaivor.Code: Select all
- Contact:
Yes, a REG_DWORD registry settings with the same name ( fs_ForceIsoForUDF102 ) under HKCU\Software\MakeMKV ._JBP_ wrote:Is there a way to use this workaround on Windows 7 64-Bit? Thanks.mike admin wrote:Never.setarip_old wrote:I'm sure "mike admin" will forgive me
I'm assuming since there wasn't a registry key there with that name I needed to create it so I did.. Do I leave the value at 0 for it? Since this is a 64-Bit system do I need to make a REG_QWORD registry key also? Will MakeMKV show anything different in the log for the different reading method? I'm only curious because it failed again... I may have to try editing out that portion of the VOB file if I can locate a editor for it as stated a few posts ago..
- Contact:
A REG_DWORD with value 0. There is no indication in the log file unfortunately._JBP_ wrote:I'm assuming since there wasn't a registry key there with that name I needed to create it so I did.. Do I leave the value at 0 for it? Since this is a 64-Bit system do I need to make a REG_QWORD registry key also? Will MakeMKV show anything different in the log for the different reading method? I'm only curious because it failed again... I may have to try editing out that portion of the VOB file if I can locate a editor for it as stated a few posts ago..
