possible to play incomplete rip?
reebok
Post by reebok »
I had another damaged bluray disc that I was able to rip a fair amount of before it failed (17.8 gigs out of 20 something). Neither zoomplayer nor MPC-HC will play it, calling it incomplete/corrupt. Is there any tool that will fix the mkv file so that what is there can be played? thanks.
Re: possible to play incomplete rip?
Post by mike admin »
reebok wrote:I had another damaged bluray disc that I was able to rip a fair amount of before it failed (17.8 gigs out of 20 something). Neither zoomplayer nor MPC-HC will play it, calling it incomplete/corrupt. Is there any tool that will fix the mkv file so that what is there can be played? thanks.
You can make a full disc backup with MakeMKV, then demux M2TS file and either play it directly or remux with mmg. Still no guarantee that it will work.
The easiest way would be to open the disc in MakeMKV, select streaming and either watch the disc or save the m2ts file in browser.
reebok
Post by reebok »
thanks mike.
