Beta Key Has Expired
Fortyniner
Post by Fortyniner »
The Beta Key at viewtopic.php?f=5&t=1053 expired on Nov 30 and there is now no way to run makemkv on Linux. Will someone please update it? Alternatively, an official release on Linux would be another good solution. I would gladly pay for it, it's worth it :-).
Re: Beta Key Has Expired
The key is updated when the author gets around to it. Usually, it's within a week of expiration. The check is only done when the program starts, so some people change their system date temporarily, start the program, then restore the system to the proper date.
The "official release" works for all supported operating systems, so buying a key enables the program for Windows, Linux, and Mac, with the same key.
