Keep getting this, sometimes it says 1 hash but tried a dozen times
Here’s the error:
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '8110866432'
Failed to save title /BDMV/STREAM/00006.m2ts to file /Volumes/easystore 3/l;/DOCTOR_WHO_S1_D1/BDMV/STREAM/00006.m2ts
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00004.m2ts' at offset '1298006016'
Failed to save title /BDMV/STREAM/00004.m2ts to file /Volumes/easystore 3/l;/DOCTOR_WHO_S1_D1/BDMV/STREAM/00004.m2ts
Encountered 170 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Backup done but 2 files failed hash check
2 hash error
Re: 2 hash error
Medium Error refers to the disc being the "medium"
The uncorrectable error means that the drive is having issues reading the disc.
This can be either due to damage or dust on the disc surface.
I have even seen finger prints cause these errors
Give the disc a clean with a good quality microfiber cloth and dampen the cloth with a bit fo water, clean from inside disc to outside and try again ripping again.
