It's the hardest of all to flash but it can work but the best Uhd drive are pioneersghostserverd wrote: ↑Fri Dec 01, 2023 7:32 pmAny reason not to pick up this BP50NB40 https://www.bestbuy.com/site/lg-8x-exte ... Id=9243009 with an expectation to be able to flash it to rip UHD Bluray disks via makemkv?
Is the only way to determine "SVC NS50+ LG only on label for NB drives NB50+" to buy it and make sure it only has the LG label on it? Or is there something in the listing I should be looking for?
Ultimate UHD Drives Flashing Guide Updated 2025
Is it hard to flash just because you have to flash it in succession with multiple firmwares likeBillycar11 wrote: ↑Fri Dec 01, 2023 7:54 pmIt's the hardest of all to flash but it can work but the best Uhd drive are pioneers
Or is there something else to be wary of?BP50NB40 to > BP50NB40-NB50-1.03MK then to > BP60NB10 1.02MK or 1.00MK
Also how can I tell if that one I linked is
to determine if it's flashable or will brick? Or is that something I have to check after I have the drive in hand?svc nb50+ vs svc nb40
Thanks for your response Billycar. This UHD flashing guide is awesome.
just because it requires multiple.ghostserverd wrote: ↑Fri Dec 01, 2023 8:50 pmIs it hard to flash just because you have to flash it in succession with multiple firmwares likeBillycar11 wrote: ↑Fri Dec 01, 2023 7:54 pmIt's the hardest of all to flash but it can work but the best Uhd drive are pioneers
Also how can I tell if that one I linked isto determine if it's flashable or will brick? Or is that something I have to check after I have the drive in hand?svc nb50+ vs svc nb40
on the box it should say most are nb52 now
Hello everyone,
Dumb question: I am having an issue using the command line on Mac to flash my drive. Can I flash it on Windows with the GUI, then use it on my Mac?
Yes
Hi, I need some help flashing my drive. I am not sure what to do. I have tried SDFFlash tool and it comes up with the same error each time.
Product: BD-RE BU40N
Revision: 1.04
Serial number: MO4N7I93554
Firmware date: 2120-05-06 11:42
Highest AACS version: 62
Harware support: Yes
Firmware support: No
Firmware version: 1.04
Any help please would be much appreciated.
Revision: 1.04
what would that error be?
what fw are you trying to flash ?
did you use enc?
Thank you! Works perfectly.
Ordered an wh16ns40 on amazon. Was able to flash to firmware 1.02 using the youtube video link. it says libre drive is enabled and i'm on mt1959. When i put a disc into the drive, it doesn't recognize it however. It doesn't recognize blu-rays either. i forgot to put a bluray in when i first received the drive. Any suggestions? Or is this a dead drive?
I'm connected via this external sata adapter w/usb plug and separate power cable. Here's the link: https://www.amazon.com/gp/product/B00MV ... =UTF8&th=1
OS device name: E:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: KLZN8SJ3617
Highest AACS version: 81
Firmware version: 1.02
OS device name: E:
Revision: 1.02
Is it one of the recommend adapters not all powered adapters support optical drivesomk1980 wrote: ↑Thu Dec 07, 2023 9:36 pmOrdered an wh16ns40 on amazon. Was able to flash to firmware 1.02 using the youtube video link. it says libre drive is enabled and i'm on mt1959. When i put a disc into the drive, it doesn't recognize it however. Any suggestions? I'm connected via an external sata adapter w/usb plug and separate power cable.
And what's the build date on the drive case
Build date is 8/28/2023.Billycar11 wrote: ↑Thu Dec 07, 2023 9:47 pmIs it one of the recommend adapters not all powered adapters support optical drivesomk1980 wrote: ↑Thu Dec 07, 2023 9:36 pmOrdered an wh16ns40 on amazon. Was able to flash to firmware 1.02 using the youtube video link. it says libre drive is enabled and i'm on mt1959. When i put a disc into the drive, it doesn't recognize it however. Any suggestions? I'm connected via an external sata adapter w/usb plug and separate power cable.
I've updated post w/link and drive profile
It's probably the adapters did it work before you flashed it?omk1980 wrote: ↑Thu Dec 07, 2023 9:49 pmBuild date is 8/28/2023.Billycar11 wrote: ↑Thu Dec 07, 2023 9:47 pmIs it one of the recommend adapters not all powered adapters support optical drivesomk1980 wrote: ↑Thu Dec 07, 2023 9:36 pmOrdered an wh16ns40 on amazon. Was able to flash to firmware 1.02 using the youtube video link. it says libre drive is enabled and i'm on mt1959. When i put a disc into the drive, it doesn't recognize it however. Any suggestions? I'm connected via an external sata adapter w/usb plug and separate power cable.
Get one of the recommend ones if not first post has some
I didn't get a chance to try it w/a bluray before flashing.Billycar11 wrote: ↑Thu Dec 07, 2023 9:53 pmIt's probably the adapters did it work before you flashed it?omk1980 wrote: ↑Thu Dec 07, 2023 9:49 pmBuild date is 8/28/2023.Billycar11 wrote: ↑Thu Dec 07, 2023 9:47 pm
yeah, looks to be the adapte.r plugged it directly into my PC and it's recognizing the disk. ripping now. Hoping it works okBillycar11 wrote: ↑Thu Dec 07, 2023 9:53 pmIt's probably the adapters did it work before you flashed it?omk1980 wrote: ↑Thu Dec 07, 2023 9:49 pmBuild date is 8/28/2023.Billycar11 wrote: ↑Thu Dec 07, 2023 9:47 pm
I just retrieved an Asus BC-12D2HT with firmware 3.00, manufactured early 2016. It looks like it's UHD friendly out of the box... are there any good reasons to flash it to a newer firmware such as 3.11_MK, or should I stay with 3.00 ?
