External Blu Ray Drive for Mac OS X
cologne
#1 Post by cologne » Wed Jul 13, 2011 11:12 am
hello people!
my plan: rip my blu rays to .mkv -> first I need an external player for
my macbbok pro, but which one I should take, which one you have?
for any further informations you would help me so much!
many thanks in advance! mark :wink:
Macbook Pro i7 Quad 2,3 Ghz | Mac OSX 10.6.8
dpstjp
Re: External Blu Ray Drive for Mac OS X
#2 Post by dpstjp » Wed Jul 13, 2011 11:37 am
I use a Buffalo BD drive, though I'm sure any will do.
cologne
#3 Post by cologne » Wed Jul 13, 2011 1:36 pm
@ dpstjp: thanks for reply, I checked the Buffalo (BR-X816U2-EU Blu-ray Drive USB2.0 extern)
8x speed ...
BUT:
Do you use the Buffalo with a mac? Thats the important point of my topic. Also I read nothing
about using with a mac in the system requirements: ... only windows.
The others? Which external blu ray drive you use with A MAC ?
crowfax
#4 Post by crowfax » Wed Jul 13, 2011 2:00 pm
Drives are drives. They take an input and feed it to your computer.
I reccomend the Plextor PX-B310U. I've suggested it to other Mac users and none of them have come back saying it doesn't work. I use it with Linux and Windows 7.
cologne
#5 Post by cologne » Wed Jul 13, 2011 2:22 pm
@ crowfax:
Fantatsic. Okay, If I understand correct: There is no OS support required. The system
and exactly the software (MakeMKV) is able to work, beacause Plextor or Buffalo only
write about XP, Vista -> OS: Windows. Not Mac. That?s the point. (Drives are drives.)
I hestitate about buying ... ;-/
crowfax
#6 Post by crowfax » Wed Jul 13, 2011 3:59 pm
Last time I checked (and it was a while ago), if you want you box to say your hardware supports Apple you had to send it off to them for testing, which they charge for. Then pay them even more money if you want to put a label on the box saying it works on a Mac. Very few hardware manufacturers are going to bother with this. One exception is LaCie who sell the same hard drive in 2 different boxes, one of them says it works on the Mac and costs $20 more than the other does. The contents of the box are the same.
If you're that worried then buy it from somewhere with a good returns policy.
cologne
#7 Post by cologne » Thu Jul 14, 2011 8:36 am
All right then! I think I will buy a nice plextor ... but it would be nice to read sth. like that: Yes, I have a mac and I use the extern player XY and it works perfectly 1. with the mac os ans 2. with MakeMKV ... you know ;-)
Okay, I try a plextor player first, ... ;-)
priitv8
#8 Post by priitv8 » Thu Jul 14, 2011 7:11 pm
I took this advice and went for a LG BH10LS30 drive, installed the riplock-free firmware and now it performs perfectly.
Inssomniak
#9 Post by Inssomniak » Thu Jul 14, 2011 9:46 pm
priitv8 wrote:I took this advice and went for a LG BH10LS30 drive, installed the riplock-free firmware and now it performs perfectly.
Can I have your riplock-free firmware? And how did you install the firmware with your mac?
#10 Post by mike admin » Sat Jul 16, 2011 11:44 am
Download the firmware update from LG and patch with http://ala42.cdfreaks.com/MCSE/ . You will need a winows box or windows in virtual machine.
