Re: Pioneer firmware update February 2023
Post by Coopervid » Sun Nov 05, 2023 1:08 pm
chooch wrote:
Sun Nov 05, 2023 1:03 pm
Coopervid wrote:
Sun Nov 05, 2023 10:45 am
chooch wrote:
Sat Nov 04, 2023 11:31 pm
Even if the firmware is after 12/2022? I thought that was the criteria when looking for a drive however didn't know if that recently changed since I'm currently in the market for one myself.
The statement about 208 or higher is only applicable if the firmware on these drives is older than Dec. 2022.
Ok, thanks. I wasn't sure if something changed and someone found a way to get it to work on drives post Dec 2022 because I thought that might be a possibility down the road.
Mike is still working on a solution but it takes far more time than he expected in the first place.
billbillw
Post by billbillw » Mon Nov 06, 2023 3:21 pm
chooch wrote:
Sun Nov 05, 2023 1:02 pm
I plan on doing that and reaching out to billbillw once I get more storage added to my server.
I won't be able to help you...I think you meant Billycar11 :lol:
chooch
Post by chooch » Mon Nov 06, 2023 3:32 pm
haha, yea I meant Billycar11 and apologize for that :lol:
pmarc14
Post by pmarc14 » Mon Nov 20, 2023 9:12 pm
I am completely new too this so I hope I am not bothering with an old question, but the new encrypted firmware date is Decemeber 2022, does that mean all drives manufactured December 2022 onwards as labeled on the box have the new 1.04 firmware or up or do drives manufactured on December 2022 itself possibly be ok?
Post by MartyMcNuts » Mon Nov 20, 2023 10:42 pm
If the date is Dec 2022 or newer then it's a no go, therefore, Nov 2022 or earlier is ok.
Darkk
Post by Darkk » Wed Nov 29, 2023 2:06 am
I am looking into getting the Pioneer BDR-212 to add the mix of my LG BD-RE WH16NS60 collection. Is it still a issue that newer firmware not "cracked" yet?
My three LG BD-RE WH16NS60 are working fine with blu-rays and 4K discs. Although ran into a few that can't read the discs at all. So wondering if Pioneer BDR-212 can read them while LG drives can't?
Post by dcoke22 » Wed Nov 29, 2023 3:10 am
Yes, still an issue.
tDwtp
Post by tDwtp » Thu Nov 30, 2023 6:47 pm
I am somewhat new to the game.
I used an internal drive until now and it worked great. I do not have a (working) caddy and I tried 2 by now.
So i bought a pioneer external UHD drive "BDR-XS07UHD" (I have a new PC so no internal Drive anymore).
I am unsure if this fits this thread. It says Firmware 1.01/ID05 and it seems to have LibreDrive enabled.
However, I can't rip anything: It simply stops after about 200MB - 300MB.
Those are my Drive infos (in german):
Laufwerksinformation
OS-Gerätename: D:
Produzent: PIONEER
Produkt: BD-RW BDR-XS07U
Revision: 1.01
Serienummer: BFDL006561WL
Firmware-Datum: 2020-09-03
Markierungen der Bus-Verschlüsselung: 13
Highest AACS version: 81
Drive platform: RS8E21
Firmware version: 1.01/ID05
Keine Disk eingelegt
Usually I'd reseat the BD, but this does not help. Trying to scan the disk did not yield any usefull errors.
It is rather generic. My best guess would be, power? it has a barrel jack, but I do not have a power supply for it.
Any tips?
With sample disc (some anime)
OS-Gerätename: \Device\CdRom0
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Revision: 1.01
Disk-Informationen
Label: GENERIC
Zeitstempel: 2023-06-22 15:46:44
Schutz: AACS v81
Datenkapazität: 18.6 Gb
Disk-Typ: BD-ROM
Anzahl der Layer: 1
Kanal-Bitlänge: 74,5 nm (max. 25.0 GB pro Layer)
the log:
MakeMKV v1.17.5 win(x64-release) gestartet
Using LibreDrive mode (v01.0 id=1534D764B687)
Direkter Zugriffsmodus wird verwendet
Inhalte-Hashtabelle geladen, überprüfe Integrität der M2TS-Dateien.
Datei 00000.mpls wurde als Titel 0 hinzugefügt
Datei 00003.mpls wurde als Titel 1 hinzugefügt
Datei 00002.mpls wurde als Titel 2 hinzugefügt
Datei 00005.mpls wurde als Titel 3 hinzugefügt
Datei 00004.mpls wurde als Titel 4 hinzugefügt
Datei 00001.mpls wurde als Titel 5 hinzugefügt
Datei 00013.m2ts wurde als Titel 6 hinzugefügt
Datei 00008.m2ts wurde als Titel 7 hinzugefügt
Datei 00015.m2ts wurde als Titel 8 hinzugefügt
Datei 00012.m2ts wurde als Titel 9 hinzugefügt
Datei 00010.m2ts wurde als Titel 10 hinzugefügt
Datei 00014.m2ts wurde als Titel 11 hinzugefügt
Titel #00017.m2ts hat eine Länge von 0 Sekunden und wurde übersprungen, da die minimale Titellänge 1 Sekunden beträgt
Datei 00006.m2ts wurde als Titel 12 hinzugefügt
Datei 00002.m2ts wurde als Titel 13 hinzugefügt
Die Aufgabe wurde erfolgreich abgeschlossen
14 Titel werden in Verzeichnis E:/Load/GENERIC gespeichert
Error 'Betriebssystemfehler - Die Anforderung konnte wegen eines E/A-Gerätefehlers nicht ausgeführt werden' occurred while writing data to 'E:/Load/GENERIC/GENERIC_t00_sn00000.mkv' at offset '0'
Titel 0 in Datei E:/Load/GENERIC/GENERIC_t00_sn00000.mkv zu speichern schlug fehl
gpmc01
Post by gpmc01 » Fri Dec 01, 2023 3:01 pm
Hi there,
I'm new to UHD-BD ripping and copying since I purchased a Pioneer Portable BDR-XS07TS from Asmcom guys (excellent service, they are super-recommended) and I'm looking for high quality BD-XL discs to make reliable backups of my UHD Bluray collection.
Do you have some brands to recommend?
Thanks in advance!
jinx100
Post by jinx100 » Fri Dec 01, 2023 3:54 pm
Writable Blu-Ray discs are not suitable for long term storage. M-Disc is marginally better but a hard drive is best. Your original printed disc is also reliable. Many MKV users use a networked hard drive system for playback and keep the original discs for backup. If you want to be doubly secure, keep two hard drive copies.
zaqqaz6917
Post by zaqqaz6917 » Fri Dec 01, 2023 9:01 pm
Also afaik most current 4k players cannot play burnt UHD disks. And none will play triple layer UHD disks.
All will play regular Blu Ray burnt 25gb and 50 gb disks.
All above is afaik
I believe the Panasonic ub900, not 9000, could play all burnt disks but it does not have Dolby vision
gpmc01
Post by gpmc01 » Sat Dec 02, 2023 5:45 am
Thanks for your replies.
I also noted that even small BD-XL packs (5 discs) are very expensive so it's definitely more convenient to go with high capacity hard drives.
tDwtp
Post by tDwtp » Sat Dec 02, 2023 11:39 am
I found out, the target drive I was saving to got corrupted on the first try after about 200 MB...
It was a writing not a reading error...
Chaos_Sandwich
Post by Chaos_Sandwich » Thu Dec 07, 2023 7:52 pm
Any updates for if 1.03 will be supported by MakeMKV?
New to this whole thing, is it that 1.03 will be supported its just a matter of time, or is 1.03 completely unable to be supported?
My drive is the Pioneer XS07
CoffeeDrinker
Post by CoffeeDrinker » Fri Dec 08, 2023 9:02 pm
I think we just have to wait. From what I can understand, Mike will release updates when they're ready, he's not going to tell us anything about the progress until it's time.
