Ultimate UHD Drives Flashing Guide Updated 2025
ghostserverd wrote:
Fri Dec 01, 2023 7:32 pm
Any reason not to pick up this BP50NB40 https://www.bestbuy.com/site/lg-8x-exte ... Id=9243009 with an expectation to be able to flash it to rip UHD Bluray disks via makemkv?
Is the only way to determine "SVC NS50+ LG only on label for NB drives NB50+" to buy it and make sure it only has the LG label on it? Or is there something in the listing I should be looking for?
It's the hardest of all to flash but it can work but the best Uhd drive are pioneers
ghostserverd
Post by ghostserverd »
Billycar11 wrote:
Fri Dec 01, 2023 7:54 pm
Is it hard to flash just because you have to flash it in succession with multiple firmwares like
BP50NB40 to > BP50NB40-NB50-1.03MK then to > BP60NB10 1.02MK or 1.00MK
Or is there something else to be wary of?
Also how can I tell if that one I linked is
svc nb50+ vs svc nb40
to determine if it's flashable or will brick? Or is that something I have to check after I have the drive in hand?
Thanks for your response Billycar. This UHD flashing guide is awesome.
ghostserverd wrote:
Fri Dec 01, 2023 8:50 pm
just because it requires multiple.
on the box it should say most are nb52 now
JTNJ32
Post by JTNJ32 »
Hello everyone,
Dumb question: I am having an issue using the command line on Mac to flash my drive. Can I flash it on Windows with the GUI, then use it on my Mac?
JTNJ32 wrote:
Sat Dec 02, 2023 3:11 pm
Hello everyone,
Yes
MacPerry
Post by MacPerry »
Hi, I need some help flashing my drive. I am not sure what to do. I have tried SDFFlash tool and it comes up with the same error each time.
Product: BD-RE BU40N
Revision: 1.04
Serial number: MO4N7I93554
Firmware date: 2120-05-06 11:42
Highest AACS version: 62
Harware support: Yes
Firmware support: No
Firmware version: 1.04
Any help please would be much appreciated.
MacPerry wrote:
Sat Dec 02, 2023 10:12 pm
what would that error be?
what fw are you trying to flash ?
did you use enc?
JTNJ32
Post by JTNJ32 »
Billycar11 wrote:
Sat Dec 02, 2023 9:44 pm
Hello everyone,
Yes
Thank you! Works perfectly.
omk1980
Post by omk1980 »
Ordered an wh16ns40 on amazon. Was able to flash to firmware 1.02 using the youtube video link. it says libre drive is enabled and i'm on mt1959. When i put a disc into the drive, it doesn't recognize it however. It doesn't recognize blu-rays either. i forgot to put a bluray in when i first received the drive. Any suggestions? Or is this a dead drive?
I'm connected via this external sata adapter w/usb plug and separate power cable. Here's the link: https://www.amazon.com/gp/product/B00MV ... =UTF8&th=1
OS device name: E:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: KLZN8SJ3617
Highest AACS version: 81
Firmware version: 1.02
omk1980 wrote:
Thu Dec 07, 2023 9:36 pm
Ordered an wh16ns40 on amazon. Was able to flash to firmware 1.02 using the youtube video link. it says libre drive is enabled and i'm on mt1959. When i put a disc into the drive, it doesn't recognize it however. Any suggestions? I'm connected via an external sata adapter w/usb plug and separate power cable.
Is it one of the recommend adapters not all powered adapters support optical drives
And what's the build date on the drive case
omk1980
Post by omk1980 »
Billycar11 wrote:
Thu Dec 07, 2023 9:47 pm
Build date is 8/28/2023.
I've updated post w/link and drive profile
omk1980 wrote:
Thu Dec 07, 2023 9:49 pm
It's probably the adapters did it work before you flashed it?
Get one of the recommend ones if not first post has some
omk1980
Post by omk1980 »
Billycar11 wrote:
Thu Dec 07, 2023 9:53 pm
I didn't get a chance to try it w/a bluray before flashing.
omk1980
Post by omk1980 »
yeah, looks to be the adapte.r plugged it directly into my PC and it's recognizing the disk. ripping now. Hoping it works ok
_nmd_
Post by _nmd_ »
I just retrieved an Asus BC-12D2HT with firmware 3.00, manufactured early 2016. It looks like it's UHD friendly out of the box... are there any good reasons to flash it to a newer firmware such as 3.11_MK, or should I stay with 3.00 ?
