Buzzlite1926
Re: SDFtool Flasher
P.s. how do I know it will work now?
Re: SDFtool Flasher
put in a UHD disc?
before it would not have seen that
kangkeelek85
Re: SDFtool Flasher
Newbie to ripping 4k, I just purchased an Asus BW-16D1HT drive hoping to flash it with the SDFtool Flasher (v1.3.5) that I already downloaded along with the "All You Need Firmware" pack. I don't have the drive yet as it is being shipped but I downloaded the flasher just to see what it looks like just and make sure it opens (preparing to know what to do when I get the drive, tomorrow). I have a few questions:
1. I am supposed to see a Microsoft . NET error before I get to the Flasher? I have the latest .net update installed. It says " Unhandled exception has occurred in your application, If you click continue, the app will ignore this error and attempt to continue."
2. When I continue on anyways, The Flasher doesn't show any drives in the drop down menu...is it built to only recognize certain model drives? or should it recognize any bluray drive connected to my computer?
All the steps outline in this forum seem super simple, but i don't know if what I am seeing is normal. Any help is appreciated.
Im running Windows 11 Home 64 bit
Re: SDFtool Flasher
Is MakeMKV installed? SDFtool Flasher is a front-end for the native MakeMKV CLI flash tool, not a stand-alone.kangkeelek85 wrote: Fri Dec 01, 2023 2:43 pm Hello,
kangkeelek85
Re: SDFtool Flasher
Yes I have MakeMKV installed, but do I have to have it open at the same time as the SDF Tool Flasher for the Flasher to work?
Re: SDFtool Flasher
No, but does MakeMKV see your drive(s)? No experience w/ Win11 "idiosyncrasies" to draw on...kangkeelek85 wrote: Fri Dec 01, 2023 4:34 pm Yes I have MakeMKV installed, but do I have to have it open at the same time as the SDF Tool Flasher for the Flasher to work?
Buzzlite1926
Re: SDFtool Flasher
Ok sobits not reading the 4k disc!!!!!! So wth!!!
Buzzlite1926
Re: SDFtool Flasher
Ok so its not reading the 4k disc!!!!!! So wth!!!
Buzzlite1926
Re: SDFtool Flasher
Not working. It still has the fw 1.03
Buzzlite1926
Re: SDFtool Flasher
This is what it showes
Info
OS device name: F:
Manufacturer; HL-DT-ST
Product: BD-RE BP50NB40
Revision: 1.03
Serial number:
Firmware date: 2120-05-07:09:17
Highest AACS version: 68
Firmware version: 1.03
Unrestricted read speed: `Yes
Info
OS device name: F:
Revision: 1.03
Serial number:
Buzzlite1926
Re: SDFtool Flasher
This was b4 the flash
Info
OS device name: F:
Revision: 1.03
Serial number:
Firmware date: 2121-07-08 16:03
Harware support: Yes
Firmware support: No
Unrestricted read speed: Possible (with patched frmare)
Info
OS device name: F:
Revision: 1.03
Serial number:
Buzzlite1926
Re: SDFtool Flasher
v1.15.2 or greater installed and that the drive is empty and tray closed.
To flash the BP50NB40 SVC:NB52, using the latest SDFtool Flasher, follow the steps below:
1. Flash the drive to BP50NB40 (NB50) 1.03-MK.
Now for the cross-flash:
2. Select the RECOVERY option and in the pop up window, select the BP50NB40 (NB50) 1.03-MK firmware that you just flashed.
3. Select the BU40N 1.00 firmware in the normal drop box.
4. Click START
This is not making sense!
4. Click START
( ͡° ͜ʖ ͡°)
Re: SDFtool Flasher
Hey, where is this (BU40N 1.00) firmware you mention, as I only see in your (The all you need firmware pack) inside (LG slim BU40N) folder (HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin) it is BU40N-1.03, not BU40N-1.00?.MartyMcNuts wrote: Wed Nov 29, 2023 5:17 amBefore you begin, ensure you have MakeMKV v1.15.2 or greater installed and that the drive is empty and tray closed.Buzzlite1926 wrote: Wed Nov 29, 2023 2:11 am Still error code 0x82052603......sooo nothing is working
4. Click START
If you follow these steps exactly it should work.
I have a LG-BP50NB40 external slim Blu-ray player which is SVC:NB52. I flash it to HL-DT-ST-BD-RE_BP50NB40-NB50-1.03-NM00800-212005070917.bin, than recover it to DE_LG_BP60NB10_1.00_MK_HBD.bin, and I can read 4K discs, everything is working ok. But you mention (Also I recommend you use the BU40N 1.00 firmware as it is better than the BP60NB10 firmware.) What's the differences between DE_LG_BP60NB10_1.00_MK_HBD.bin and BU40N 1.00, should I flash it to BU40N, or stay with DE_LG_BP60NB10_1.00_MK_HBD.bin?
Buzzlite1926
Re: SDFtool Flasher
I need step by step precise instructions to do this. I never done this before! There's too much of downloading and different directions it's too much.
Re: SDFtool Flasher
I don't know about Billy's "All you need firmware pack" but it is in mine! DL link on first page of this thread.( ͡° ͜ʖ ͡°) wrote: Mon Dec 04, 2023 5:19 amHey, where is this (BU40N 1.00) firmware you mention, as I only see in your (The all you need firmware pack) inside (LG slim BU40N) folder (HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin) it is BU40N-1.03, not BU40N-1.00?.MartyMcNuts wrote: Wed Nov 29, 2023 5:17 amBefore you begin, ensure you have MakeMKV v1.15.2 or greater installed and that the drive is empty and tray closed.Buzzlite1926 wrote: Wed Nov 29, 2023 2:11 am Still error code 0x82052603......sooo nothing is working
4. Click START
BU40N 1.00 is better than BP60NB10 firmware as it is compatible with all popular ripping software. BP60NB10 firmware only works with MakeMKV and AnyDVD software.
