How to add license for a machine that only runs makemkvcon
LGTrader
Post by LGTrader »
For a server type machine with no X on it, but makemkvcon installed, how do I provide my license number?
Thanks in advance.
Re: How to add license for a machine that only runs makemkvcon
I don't use MakeMKV on Linux, but there's this thread: viewtopic.php?f=3&t=28684
LGTrader
Post by LGTrader »
Thanks. Between that thread and some comments elsewhere I realized I should not look at the man page online at sites I know nothing about but rather I should run
makemkvcon --help
which showed an option
makemkvcon reg KEY
Running that command appears to have solved the segfault problem in my other thread so all is good now.
Note that this command does NOT apparently create the same settings.conf file but appears to put the key somewhere else. None the less all 3 of my machines now run makemkvcon, apparently successfully.
