M3GAN UHD - Dump File
Evening,
M3GAN dump file sent
MKB20_v77_M3GAN_AF42
Obsessive compulsive ripper and collector since finding Make MKV!
Converting nearly 1,200 Blu Rays and UHD in 1:1 format to a Plex library serviced by Infuse.
Re: M3GAN UHD - Dump File
I've sent this one in a couple of time but no joy yet...
viewtopic.php?f=12&t=32284
Maybe there's an issue with this disc?
I assume Mike is a busy man, took around a week for the Nun 2 to get fixed!
Tried again tonight and it failed again.
Still failing, has anybody managed to rip this title yet?
Nope - still getting volume key unknown error message on this one.
If it helps I used AnyDVD in the end to get this 4k version ripped.
Still failing, I've never had a disk take this long to be unlocked previously after sending a dump file through..
Don't get me wrong, I can assume some work needs doing by people/persons and therefore I'm not trying to moan or be a dick - is there anything I can do to help or speed this process up?
All,
Is this defiantly a "key" issue?
Using LibreDrive mode (v01.0 id=F1ED73020654)
Saved AACS dump file as C:\Users\jtaylor/.MakeMKV/MKB20_v77_M3GAN_AF42.tgz
DEBUG: Code 0 at *>y@ce*3@Z%S'=:>:213132721
DEBUG: Code 0 at *>y@ce*3@Z%S'=:>:213131341
Reason I ask is that I posted/emailed two other (different) dump files less than 48 hrs ago and both have now decoded, whereas this disc is still failing weeks later?
Thank you in advance,
Saved AACS dump file as C:\Users\ /.MakeMKV/MKB20_v77_M3GAN_AF42.tgz
DEBUG: Code 0 at *>y@ce*3@Z%S'=:>:121263084
Emailed twice to SVQ@makemkv.com - 3.3mb
Manufacturer: PIONEER
Product: BD-RW BDR-S12U
Revision: 1.02
Serial number: ALDL005994WL
Firmware date: 2022-03-07
Highest AACS version: 78
Drive platform: RS8F01
Firmware version: 1.02/ID43
Right I have now done an encrypted backup of this disk (stored on my external SSD) to make it easier to periodically check to see if this disc has been unlocked - which it still hasn't..
There must be something specific with this disk and its bump file that is causing such a delay, the other dumps that I have sent have been unlock in the usual 2-3 day time frame?
I know that a lot of forum members get bored to tears answering the same newb questions, over and over but what am I missing here?
I have done some reading on AACS2.1, which in fairness I'm still not fully grasping - is this disc another Zombieland issue, should I just return it and get another copy/import copy?
If I'm being dense please feel free to flame me, I won't take offence - it's just getting under my craw now as to why there is such an issue with this title.
Cheers J
Revision: 1.02
Cheers J
Thanks for the response Coopervid - just trying this now and I will report back
![Wink :wink:](./images/smilies/icon_wink.gif)
@Coopervid
Okay, no dice.. Just want to make sure I've actually doing what I need to do correctly before giving up?
Found the FindVuk 1.72 download - https://www.videohelp.com/software/FindVUK
Downloaded it and then ran "FindVUK - Synchronize" - pop up box quickly flashes up and then disappears - too fast to see what if anything it says
Checking C:/user/user/appdata/roaming - I cannot find a folder: AACS or the keydb.cfg file motioned (unhidden all folder/files)
After much messing about, I managed to follow your instructions and get the AACS file to load into AppData, copied this to .MakeMkv re-ran the "Backup" of M3GAN and it has failed again..
I will try the physical disc later tonight but I don't hold out any hope of it working. All said I would like to thank you @Coopervid for trying to assist me with this today.
One UHD version is supported. Maybe this is not.
With the help of another forum member we have come to the conclusion that this disc isn’t anything special and the Key is in the dump file that I have already sent to the SVQ email address.
For whatever reason this just hasn’t been updated in the database yet, so it’s a waiting game for the required update to be completed.
I will send the file as a One Drive link just in case it’s not getting through for some reason.
As a side note, I have also tried AnyDVD as suggested earlier and it also failed there as well.
