BD-RE BU40N Not able to load newer disc
zeyoner
Post by zeyoner »
I now have come across two (A Bronx Tale & Oppenheimer) disc my drive is unable to load. Not just in MakeMKV, but within Windows. As if the disc is unreadable. I've flashed DE 1.00, MK 1.01-1.04 firmwares. What am I missing?
OS device name: G:
Product: BD-RE BU40N
Revision: 1.03
Serial number: [redacted]
Firmware version: 1.03
Re: BD-RE BU40N Not able to load newer disc
zeyoner wrote:
Mon Nov 27, 2023 11:14 pm
I now have come across two (A Bronx Tale & Oppenheimer) disc my drive is unable to load. I've flashed clean 1.0, DE 1.0, all of the MK firmwares. What am I missing?
OS device name: G:
Revision: 1.03
The firmware on your drive is not the problem. Try posting the MakeMKV logs for those discs so we can assist you further.
zeyoner
Post by zeyoner »
I've tried the same movie different disc same issue.
Debug log started at Mon Nov 27 12:08:53 2023 , written by MakeMKV v1.17.5 win(x64-release)
001005:0000 MakeMKV v1.17.5 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\*REDACTED*/MakeMKV_log.txt
DEBUG: Code 3 at p#THBi/ll*BA2gQ6"dN^+C5W:29395310
SDF  v098: HL-DT-ST_BD-RE_BU40N_1.03_211810241934_MO9J7AH5921
Application exited at Mon Nov 27 12:17:41 2023
zeyoner
Post by zeyoner »
MartyMcNuts wrote:
Mon Nov 27, 2023 11:58 pm
Am I providing the logs you're referring to? MakeMKV does not appear to be part of the equation. The drive does not load the disc at all. You'll hear it trying to load the disc but at some point gives up. Any other disc in my collection loads without hesitation.
zeyoner wrote:
Wed Nov 29, 2023 5:28 am
if thats the case then the only solution is
cleaning the disc.
replacing the disc.
cleaning the laser very easy on a bu40n.
replacing the drive i would recommend the pioneers now no point getting a lg/asus for UHD as long as pioneers are available with old fw.
i know it sounds like a shill move but they really are way more reliable and dont do weird things that make you have to reboot them.
for the most part pioneers with old fw are only available from sellers.
Post by SamuriHL »
Trust Billy on this. I have a bu40n but pretty much only use my pioneer drives now. They are far more reliable.
zeyoner
Post by zeyoner »
Purchased a Pioneer BD-RW BDR-XS07 same results...
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-XS07
Revision: 1.01
Serial number: *redacted*
Firmware date: 2020-09-03
Bus encryption flags: 13
Highest AACS version: 70
Drive platform: RS8E20
Firmware version: 1.01
zeyoner wrote:
Wed Nov 29, 2023 6:24 pm
You know the xs07s is not a UHD drive right?
Do you have an xs07s or xs07uhd?
Likely either won't work out of the box
zeyoner
Post by zeyoner »
Billycar11 wrote:
Wed Nov 29, 2023 6:40 pm
I can return it and get XS07UHD. Thought it would be the same just a different color. Would it be worth buying though?
zeyoner wrote:
Wed Nov 29, 2023 6:47 pm
An xs07s UHD is not going to work either if it's built after 12/22.
I have pioneers with old fw getting 24 in today and another 18 on Friday.
Email me see below
Yes the pioneers are worth it.
But just to make sure is your xs07s fw after 12/22?
Because if it's before that it can be flashed
zeyoner
Post by zeyoner »
MFD. June 2022
I'm confused now. Is the xs07s flashable or should I still get myself the xs07uhd? One that's MFD before 12/22.
zeyoner wrote:
Wed Nov 29, 2023 8:20 pm
MFD. June 2022
no email the drive info for the pioneer i will send you a flasher for it for $25
zeyoner
Post by zeyoner »
What would the drive be crossed flashed to? Wouldn't that brick the drive?
Appreciate the help.
zeyoner wrote:
Wed Nov 29, 2023 8:38 pm
no if i was bricking peoples drives i would be out of business it gets flashed to the uhd version
your lucky to have an old one and my flash is cheaper then upgrading to the UHD version on amazon and the uhd one from amazon is likely to new
zeyoner
Post by zeyoner »
Billycar11 wrote:
Wed Nov 29, 2023 8:49 pm
My job is paying for the drive. Got the UHD version and it has a MFD of Feb 2023. I thought all was lost until I tried ripping and it works. Maybe firmware 1.02 is ok for now. Did some reading and it looks like 1.02 is a bit of a pain some times. Already experienced it, had to reload the disc.
