#916 Post by Billycar11 » Wed Nov 22, 2023 10:35 pm
x10bulls wrote: Wed Nov 22, 2023 5:48 pm Trying to downgrade my BW-16D1H-U PRO E116 to A203 or A204, but getting "Updating failure #1"
Any ideas why this is happening? :cry:
Sounds like your trying to flash a pioneer to an LG post the drive info
gotyouallincheck
#917 Post by gotyouallincheck » Sat Nov 25, 2023 5:50 pm
Thanks for the tool. I was able to flash a new BW-16D1HT right off the shelf (manufactured date April, 2023). It was on version 3.11 out of the box.
Buzzlite1926
#918 Post by Buzzlite1926 » Mon Nov 27, 2023 9:29 pm
What do I use to flash my LG BP50NB40 there is so many edits and software can some one make this as simple as can be plzzz!!!
#919 Post by MartyMcNuts » Mon Nov 27, 2023 9:39 pm
Buzzlite1926 wrote: Mon Nov 27, 2023 9:29 pm What do I use to flash my LG BP50NB40 there is so many edits and software can some one make this as simple as can be plzzz!!!
Buzzlite1926
#920 Post by Buzzlite1926 » Mon Nov 27, 2023 9:43 pm
I see that but there so many edit ones idk what's the right ones.
#921 Post by Coopervid » Mon Nov 27, 2023 9:46 pm
Buzzlite1926 wrote: Mon Nov 27, 2023 9:43 pm I see that but there so many edit ones idk what's the right ones.
You need to READ page one.
Buzzlite1926
#922 Post by Buzzlite1926 » Mon Nov 27, 2023 10:01 pm
Ok do I use the program and firmeware that has the latest edit dates?
Buzzlite1926
#924 Post by Buzzlite1926 » Tue Nov 28, 2023 10:11 am
Did not work!!!!!!!!!!!!!!!!!!........ :oops:
Error updating #5. Wtf!
#925 Post by Coopervid » Tue Nov 28, 2023 10:18 am
Buzzlite1926 wrote: Tue Nov 28, 2023 10:11 am Did not work!!!!!!!!!!!!!!!!!!........ :oops:
The latest version of the SDFtool Flasher has a checkbox option to flash the boot loader with the main firmware to the drive. This is useful for the newer BP50NB40 with SVC: NB52. It's also possible that other newer models may require this option later on. We will all work it out together as we go!!
For the moment, to flash the BP50NB40 SVC:NB52, using the latest SDFtool Flasher, follw the steps below:
1. Flash the drive to BP50NB40 (NB50) 1.03-MK.
Now for the crossflash:
2. Select the RECOVERY option and in the pop up, select the BP50NB40 (NB50) 1.03-MK firmware that you just flashed.
3. Select the BP60NB10 1.00-MK or BU40N 1.00 firmware in the normal drop box.
4. Click START
#926 Post by MartyMcNuts » Tue Nov 28, 2023 8:59 pm
Coopervid wrote: Tue Nov 28, 2023 10:18 am
4. Click START
Error updating #5...
It sounds like you are trying to use the modified ASUS flasher. You were told to use the SDFtool Flasher.
Use the SDFtool Flasher and follow the instructions exactly as Coopervid said above.
Buzzlite1926
#928 Post by Buzzlite1926 » Tue Nov 28, 2023 10:00 pm
Just post the steps and accurate software
Buzzlite1926
#929 Post by Buzzlite1926 » Tue Nov 28, 2023 10:01 pm
Plz post the right instructions and downloads I'm tired of downloading many things and reading and getting nowhere.
Buzzlite1926
#930 Post by Buzzlite1926 » Tue Nov 28, 2023 10:03 pm
