Trying to downgrade my BW-16D1H-U PRO E116 to A203 or A204, but getting "Updating failure #1"
Any ideas why this is happening?
Sounds like your trying to flash a pioneer to an LG post the drive info
Thanks for the tool. I was able to flash a new BW-16D1HT right off the shelf (manufactured date April, 2023). It was on version 3.11 out of the box.
What do I use to flash my LG BP50NB40 there is so many edits and software can some one make this as simple as can be plzzz!!!
SDFtool FlasherBuzzlite1926 wrote: ↑Mon Nov 27, 2023 9:29 pmWhat do I use to flash my LG BP50NB40 there is so many edits and software can some one make this as simple as can be plzzz!!!
I see that but there so many edit ones idk what's the right ones.
You need to READ page one.Buzzlite1926 wrote: ↑Mon Nov 27, 2023 9:43 pmI see that but there so many edit ones idk what's the right ones.
Ok do I use the program and firmeware that has the latest edit dates?
Did not work!!!!!!!!!!!!!!!!!!........
Error updating #5. Wtf!
The latest version of the SDFtool Flasher has a checkbox option to flash the boot loader with the main firmware to the drive. This is useful for the newer BP50NB40 with SVC: NB52. It's also possible that other newer models may require this option later on. We will all work it out together as we go!!Buzzlite1926 wrote: ↑Tue Nov 28, 2023 10:11 amDid not work!!!!!!!!!!!!!!!!!!........
For the moment, to flash the BP50NB40 SVC:NB52, using the latest SDFtool Flasher, follw the steps below:
1. Flash the drive to BP50NB40 (NB50) 1.03-MK.
Now for the crossflash:
2. Select the RECOVERY option and in the pop up, select the BP50NB40 (NB50) 1.03-MK firmware that you just flashed.
3. Select the BP60NB10 1.00-MK or BU40N 1.00 firmware in the normal drop box.
4. Click START
Error updating #5...Coopervid wrote: ↑Tue Nov 28, 2023 10:18 amThe latest version of the SDFtool Flasher has a checkbox option to flash the boot loader with the main firmware to the drive. This is useful for the newer BP50NB40 with SVC: NB52. It's also possible that other newer models may require this option later on. We will all work it out together as we go!!Buzzlite1926 wrote: ↑Tue Nov 28, 2023 10:11 amDid not work!!!!!!!!!!!!!!!!!!........
4. Click START
It sounds like you are trying to use the modified ASUS flasher. You were told to use the SDFtool Flasher.
Use the SDFtool Flasher and follow the instructions exactly as Coopervid said above.
Where to get all this stuff????
Just post the steps and accurate software
Plz post the right instructions and downloads I'm tired of downloading many things and reading and getting nowhere.
