Good to know!
Oppenheimer (2023)
Re: Oppenheimer (2023)
I ripped Oppenheimer today on my M1 MacBook Pro using ffmpeg.
To get that working I did this:
Install Xcode:
Then proceed to install Homebrew
After installation check:
You should get: “Your system is ready to brew” as a reply.
Install ffmpeg:
Then install libaacs:
http://fvonline-db.bplaced.net/
KEYDB.cfg in ~/Library/Preferences/aacs/
Paste the downloaded KEYDB.cfg here.
Open the disc with MakeMKV to enable libredrive mode.
Just leave MakeMKV as is.
You can check in MakeMKV which device is your blu-ray drive.
Then in terminal: (replace /dev/rdisk4 with the address of your drive)
Install Xcode:
xcode-select --install
/bin/bash -c "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/HEAD/install.sh)"
brew doctor
Install ffmpeg:
brew install ffmpeg
brew install libaacs
cd /opt/homebrew/Cellar/libaacs
cp libaacs.0.dylib /usr/local/lib
ln -s libaacs.0.dylib libaacs.dylib
Open ~/Library/Preferences/aacs/
ffmpeg -i "bluray:/dev/rdisk4" -c copy -map 0 Oppenheimer.mkv
Me too......lawleo wrote: ↑Mon Nov 20, 2023 11:33 pmDump file sent go
svq@makemkv.com
MKB20_v77_Oppenheimer_8B8A.tgz
RobbieT1974 wrote: ↑Sat Nov 25, 2023 5:34 pmcan use just mounted drive, easier.Code: Select all
ffmpeg -i "bluray:/Volumes/OPPENHEIMER" -c copy -map 0 Oppenheimer.mkv
Got my Amazon (US) 4K UltraHD Oppenheimer (2023) disks today. The 4K disk won't even open, just sputters around for a minute and then kicks the disk out. The HD disk ripped fine, no problems. Special features disk, all good. But I can't even get a .tgz file for the 4K because it refuses to mount. Tried two different 4K optical readers, my go to being the WH16NS40 v1.02 using LibreDrive mode. Previously I've ripped 30+ UHD 4K blu-rays.... no issues. Am I missing something?
3CB4 is working now, lets hope it rips fine.
Thanks for the heads up. Ripping mine now
Probably not. Several here (including myself) have bad discs from Amazon. I've tried multiple drives as well. Try to clean the disc carefully and retry... otherwise you may have to open a return and wait awhile, Amazon shows a big delay for replacements.TORRRRR wrote: ↑Sun Nov 26, 2023 9:14 pmGot my Amazon (US) 4K UltraHD Oppenheimer (2023) disks today. The 4K disk won't even open, just sputters around for a minute and then kicks the disk out. The HD disk ripped fine, no problems. Special features disk, all good. But I can't even get a .tgz file for the 4K because it refuses to mount. Tried two different 4K optical readers, my go to being the WH16NS40 v1.02 using LibreDrive mode. Previously I've ripped 30+ UHD 4K blu-rays.... no issues. Am I missing something?
3CB4 ripped fine for me
Currently ripping 3CB4, but got 1 HashCheck Error when it was loading up the disc, relating to 00441.m2ts.
Not sure if that will cause problems, but I’m at 75% without further issues.
My 3CB4 is also working now!
8B8A also working.
3CB4 ripped fine for me, no errors.
Hitachi-LG BH16NS55 drive with 1.01 stock firmware
