Unable to rip "SpongeBob SquarePants: The Next 100 Episodes " boxset
FMTC84
Post by FMTC84 »
I bought newer DVD boxset SpongeBob SquarePants: The Next 100 Episodes and I tired my usual first (DVD Decrypter) and that did not work so I tried to use MakeMKV to rip the discs (16 discs) it says something about BUP not matching something or other. It will go very slowly for a while and they slows to a crawl with a "Ripguard" message and eventually will fail with a read error!
What gives? Is there anyway to rip these discs?
My drive is an LG BP50NB10 flashed with Libredrive
FMTC84
Re: Unable to rip "SpongeBob SquarePants: The Next 100 Episodes " boxset
Post by FMTC84 »
Okay I tried again using "Cellwalk" and it still failed and the error about the BUP was this
Calculated BUP offset for VTS #0 does not match one in IFO header.
Calculated BUP offset for VTS #1 does not match one in IFO header.
Calculated BUP offset for VTS #2 does not match one in IFO header.
Calculated BUP offset for VTS #3 does not match one in IFO header.
Calculated BUP offset for VTS #4 does not match one in IFO header.
Calculated BUP offset for VTS #5 does not match one in IFO header.
Calculated BUP offset for VTS #8 does not match one in IFO header.
Calculated BUP offset for VTS #9 does not match one in IFO header.
Calculated BUP offset for VTS #10 does not match one in IFO header.
Calculated BUP offset for VTS #12 does not match one in IFO header.
Calculated BUP offset for VTS #13 does not match one in IFO header.
You can try the different DVD opening modes.
FMTC84
Post by FMTC84 »
dcoke22 wrote: Sat Nov 25, 2023 5:38 am You can try the different DVD opening modes.
I did that already
The final error message was as follows
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading 'BD-RE HL-DT-ST BD-RE BP60NB10 1.02 K0FGA5D5838' at offset '0'
Backup failed
FMTC84 wrote: Sat Nov 25, 2023 5:21 pm
I did that already
Backup failed
Thats a power error use both USB plugs in the back of the motherboard or buy a high powered USB hub.
FMTC84
Post by FMTC84 »
Billycar11 wrote: Sat Nov 25, 2023 10:36 pm
I did that already
Backup failed
I was using the Dell WD15 dock with my Latitude 5590 with that LG drive
Anyway I forgot my HP Elitedesk 800 G4 had a DVD drive (LG GUD1N) that is powered VIA a header on the MB which in turn is powered by the PCs power supply.
I tried the backup and it still failed so I just did the MakeMKV route as I found out the MKV files where just an uncompressed container file and that worked!!
However I don't see why this worked though and the backup part failed?
I got all 16 discs ripped and I am currently using Handbrake to compress the files for my Xbox Series X
Problem solved
Thank You
FMTC84 wrote: Mon Nov 27, 2023 12:32 am
Problem solved
Thank You
from my experience usually laptop dock usb ports are underpowered
MisterFyre
Post by MisterFyre »
FMTC84 wrote: Sat Nov 25, 2023 3:42 am Okay I tried again using "Cellwalk" and it still failed and the error about the BUP was this
I've been having the same issue. I have no clue what to do.
Ninja4561
Post by Ninja4561 »
I’m a few months late, but Season 6 is authored in a weird way. Many Disney DVDs from 2005-2010 have a 5-second delay before the movie actually starts (something Paramount experimented with around 2009-2010), which can create sync issues depending on how the disc is ripped. As for SpongeBob, the first two discs of Season 6 actually have these delays between certain episodes, making it harder to rip. Ripping each individual episode from their own dedicated titles seems to work better, as it’s easier to work around the delay. Seasons 7, 8, and 9 do not have this issue.
