Oppenheimer (2023)
H3cxDev
Re: Oppenheimer (2023)
#91 Post by H3cxDev » Sat Nov 25, 2023 4:33 pm
SamuriHL wrote: Sat Nov 25, 2023 4:16 pm It takes Mike 1 to 4000 days to generate keys. Some days he's quick, other times it can take a few weeks. Usually it's in between.
Good to know!
RobbieT1974
#92 Post by RobbieT1974 » Sat Nov 25, 2023 5:34 pm
I ripped Oppenheimer today on my M1 MacBook Pro using ffmpeg.
To get that working I did this:
Install Xcode:
xcode-select --install
Then proceed to install Homebrew
/bin/bash -c "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/HEAD/install.sh)"
After installation check:
brew doctor
You should get: “Your system is ready to brew” as a reply.
Install ffmpeg:
brew install ffmpeg
Then install libaacs:
brew install libaacs
cd /opt/homebrew/Cellar/libaacs
cp libaacs.0.dylib /usr/local/lib
ln -s libaacs.0.dylib libaacs.dylib
http://fvonline-db.bplaced.net/
KEYDB.cfg in ~/Library/Preferences/aacs/
Open ~/Library/Preferences/aacs/
Paste the downloaded KEYDB.cfg here.
Open the disc with MakeMKV to enable libredrive mode.
Just leave MakeMKV as is.
You can check in MakeMKV which device is your blu-ray drive.
Then in terminal: (replace /dev/rdisk4 with the address of your drive)
ffmpeg -i "bluray:/dev/rdisk4" -c copy -map 0 Oppenheimer.mkv
crhendo
#93 Post by crhendo » Sat Nov 25, 2023 10:43 pm
lawleo wrote: Mon Nov 20, 2023 11:33 pm Dump file sent go
svq@makemkv.com
MKB20_v77_Oppenheimer_8B8A.tgz
Me too......
fedor
#94 Post by fedor » Sun Nov 26, 2023 6:45 am
RobbieT1974 wrote: Sat Nov 25, 2023 5:34 pm
can use just mounted drive, easier.
ffmpeg -i "bluray:/Volumes/OPPENHEIMER" -c copy -map 0 Oppenheimer.mkv
Simbo
#95 Post by Simbo » Sun Nov 26, 2023 10:59 am
Still not working ☹️
TORRRRR
#96 Post by TORRRRR » Sun Nov 26, 2023 9:14 pm
Got my Amazon (US) 4K UltraHD Oppenheimer (2023) disks today. The 4K disk won't even open, just sputters around for a minute and then kicks the disk out. The HD disk ripped fine, no problems. Special features disk, all good. But I can't even get a .tgz file for the 4K because it refuses to mount. Tried two different 4K optical readers, my go to being the WH16NS40 v1.02 using LibreDrive mode. Previously I've ripped 30+ UHD 4K blu-rays.... no issues. Am I missing something?
NGNXM8
#97 Post by NGNXM8 » Sun Nov 26, 2023 9:38 pm
3CB4 is working now, lets hope it rips fine.
popper11
#98 Post by popper11 » Sun Nov 26, 2023 10:06 pm
NGNXM8 wrote: Sun Nov 26, 2023 9:38 pm 3CB4 is working now, lets hope it rips fine.
thanks for the news! will try tomorrow too, and report
Simbo
#99 Post by Simbo » Sun Nov 26, 2023 10:38 pm
Thanks for the heads up. Ripping mine now 👍🏻
webminster
#100 Post by webminster » Sun Nov 26, 2023 10:39 pm
TORRRRR wrote: Sun Nov 26, 2023 9:14 pm Got my Amazon (US) 4K UltraHD Oppenheimer (2023) disks today. The 4K disk won't even open, just sputters around for a minute and then kicks the disk out. The HD disk ripped fine, no problems. Special features disk, all good. But I can't even get a .tgz file for the 4K because it refuses to mount. Tried two different 4K optical readers, my go to being the WH16NS40 v1.02 using LibreDrive mode. Previously I've ripped 30+ UHD 4K blu-rays.... no issues. Am I missing something?
Probably not. Several here (including myself) have bad discs from Amazon. I've tried multiple drives as well. Try to clean the disc carefully and retry... otherwise you may have to open a return and wait awhile, Amazon shows a big delay for replacements.
NGNXM8
#101 Post by NGNXM8 » Sun Nov 26, 2023 10:47 pm
3CB4 ripped fine for me :wink:
MetAlbertR
#102 Post by MetAlbertR » Sun Nov 26, 2023 11:00 pm
Currently ripping 3CB4, but got 1 HashCheck Error when it was loading up the disc, relating to 00441.m2ts.
Not sure if that will cause problems, but I’m at 75% without further issues.
FFROSCH
#103 Post by FFROSCH » Mon Nov 27, 2023 6:00 am
My 3CB4 is also working now! :D
Crappusername
#104 Post by Crappusername » Mon Nov 27, 2023 8:30 am
8B8A also working.
popper11
#105 Post by popper11 » Mon Nov 27, 2023 12:20 pm
3CB4 ripped fine for me, no errors.
Hitachi-LG BH16NS55 drive with 1.01 stock firmware
