Dragon Ball Super - Super Hero dump submitted
AmatureArchiver
Post by AmatureArchiver »
My dump file is `MKB20_v77_Dragon_Ball_Super-_Super_Hero_0424.tgz` in case it helps anyone else looking to submit.
megasamusx
Re: Dragon Ball Super - Super Hero dump submitted
Post by megasamusx »
Submitted mine last night as well.
megasamusx
Disc will open now but it won't finish ripping. Get's to the very end and then fails. 3 attempts now. Will give the disc a good iso alcohol cleaning and report back. Anyone else with issues?
InTheZoneAC
Post by InTheZoneAC »
AmatureArchiver wrote:
Fri Nov 24, 2023 8:34 pm
I had submitted as well, still can't get it to open.
InTheZoneAC
IDK if you or anyone else still has issues. For whatever reason my bitdefender firewall was blocking connections that makemkv was making, preventing any key download. I've been able to download in the past, but with warnings from bitdefender. This time it was blocking everything so I had to temporarily disable some settings in bitdefender. I tried to add exceptions for makemkv in various areas of the software, but nothing helped until I disabled a setting that allowed the connections to be made.
