biet1234
Post by biet1234 » Sat Nov 25, 2023 10:46 am
thank you for these scripts! sorry for beginner question.
I have a mkv file with 1 HDR track and 1 dts 5.1 audio track. I want to remux to mkv file with original HDR video track and the audio track converted to Dolby digital (plus). Is this currently possible with these scripts?
Post by RESET_9999 » Sat Nov 25, 2023 1:36 pm
TheEqualizer wrote: Sat Nov 25, 2023 7:40 am And also, for interest, I ran the finished movie through the script, the script completely recoded all the sound from eac3 to ac3, spoiling it, he can't just transfer everything from the mkv container to mp4 without changes?
what? that's not possible. First, the script only has codes to encode DDP and not DD and secondly, the script will encode only lossless audio which you can disable at line 65.
As for the delay, I use delay cut and it changes the codec id but the file still play in DDP fine.
can you give me your problematic file?
original mkv with delay:
General
Unique ID                                : 208454677894262685689253237183981859474 (0x9CD2E91E6B684914814CCEF6F76CB292)
Complete name                            : D:\P5 SRT EC3 FORCESDR delay.mkv
File size                                : 730 MiB
Duration                                 : 5 min 7 s
Overall bit rate                         : 19.9 Mb/s
Frame rate                               : 24.000 FPS
Writing application                      : mkvmerge v79.0 ('Funeral Pyres') 64-bit
Writing library                          : libebml v1.4.4 + libmatroska v1.7.1
Video
Format profile                           : Main 10@L5@Main
HDR format                               : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU
Duration                                 : 5 min 6 s
Bit rate                                 : 18.0 Mb/s
Chroma subsampling                       : 4:2:0
Bits/(Pixel*Frame)                       : 0.091
Stream size                              : 658 MiB (90%)
Color range                              : Full
Audio #1
Format                                   : E-AC-3 JOC
Format/Info                              : Enhanced AC-3 with Joint Object Coding
Commercial name                          : Dolby Digital Plus with Dolby Atmos
Codec ID                                 : A_EAC3
Bit rate                                 : 768 kb/s
Delay relative to video                  : 1 s 222 ms
Stream size                              : 28.0 MiB (4%)
Complexity index                         : 16
Number of dynamic objects                : 15
Audio #2
Format                                   : E-AC-3
Codec ID                                 : A_EAC3
Duration                                 : 4 min 0 s
Bit rate                                 : 1 536 kb/s
Frame rate                               : 62.500 FPS (768 SPF)
Stream size                              : 44.1 MiB (6%)
Text #1
Format                                   : UTF-8
Codec ID                                 : S_TEXT/UTF8
Codec ID/Info                            : UTF-8 Plain Text
Duration                                 : 3 min 53 s
Bit rate                                 : 38 b/s
Frame rate                               : 0.150 FPS
Count of elements                        : 35
Stream size                              : 1.09 KiB (0%)
Title                                    : forced
Forced                                   : Yes
Text #2
Format                                   : UTF-8
Duration                                 : 2 min 37 s
Bit rate                                 : 44 b/s
Frame rate                               : 0.172 FPS
Count of elements                        : 27
Stream size                              : 874 Bytes (0%)
Title                                    : English
Text #3
Format                                   : UTF-8
Duration                                 : 2 min 38 s
Bit rate                                 : 68 b/s
Frame rate                               : 0.183 FPS
Count of elements                        : 29
Stream size                              : 1.33 KiB (0%)
Title                                    : Bulgarian (Bulgaria)
Language                                 : Bulgarian
Text #4
Format                                   : UTF-8
Bit rate                                 : 41 b/s
Stream size                              : 816 Bytes (0%)
Title                                    : Croatian (Croatia)
Language                                 : Croatian
Text #5
Format                                   : UTF-8
Bit rate                                 : 38 b/s
Stream size                              : 771 Bytes (0%)
Title                                    : Czech (Czechia)
Language                                 : Czech
the output of workflow 5 with delay fixed:
General
Complete name                            : D:\P5 SRT EC3 FORCESDR delay_P5_DoVi.mp4
Format                                   : mp43
Codec ID                                 : mp43 (isom/mp43/dby1)
File size                                : 730 MiB
Encoded date                             : 2023-11-25 13:29:44 UTC
Tagged date                              : 2023-11-25 13:29:44 UTC
Writing application                      : GPAC-1.1.0-DEV-rev1027-g1daa0b5f-master
Video
Encoded date                             : 2023-11-25 13:29:43 UTC
Tagged date                              : 2023-11-25 13:29:45 UTC
Color range                              : Full
Audio #1
Format                                   : E-AC-3 JOC
Codec ID                                 : ac-3
Bit rate                                 : 768 kb/s
Maximum bit rate                         : 811 kb/s
Stream size                              : 28.2 MiB (4%)
Title                                    : DDP
Encoded date                             : 2023-11-25 13:29:45 UTC
Complexity index                         : Not present / 16
Audio #2
Format                                   : E-AC-3
Codec ID                                 : ac-3
Duration                                 : 4 min 1 s
Maximum bit rate                         : 1 573 kb/s
Stream size                              : 44.3 MiB (6%)
Title                                    : DDP
Text #1
Format                                   : Timed Text
Codec ID                                 : tx3g
Bit rate                                 : 42 b/s
Frame rate                               : 0.249 FPS
Stream size                              : 1.23 KiB (0%)
Title                                    : SRT
Forced                                   : Yes
Count of events                          : 35
Text #2
Format                                   : Timed Text
Codec ID                                 : tx3g
Bit rate                                 : 34 b/s
Frame rate                               : 0.220 FPS
Stream size                              : 1 021 Bytes (0%)
Title                                    : SRT
Count of events                          : 27
Text #3
Format                                   : Timed Text
Codec ID                                 : tx3g
Duration                                 : 4 min 2 s
Bit rate                                 : 50 b/s
Frame rate                               : 0.235 FPS
Stream size                              : 1.48 KiB (0%)
Title                                    : SRT
Count of events                          : 29
Text #4
Format                                   : Timed Text
Codec ID                                 : tx3g
Bit rate                                 : 32 b/s
Stream size                              : 971 Bytes (0%)
Title                                    : SRT
Language                                 : Croatian
Text #5
Format                                   : Timed Text
Codec ID                                 : tx3g
Bit rate                                 : 31 b/s
Stream size                              : 929 Bytes (0%)
Title                                    : SRT
Language                                 : Czech
TheEqualizer
Post by TheEqualizer » Sat Nov 25, 2023 1:58 pm
Another nuance is whether it is possible to somehow save all the signatures that were in mkv, otherwise the script changes the names of the tracks. In other words, you need a full copy of the entire contents of the mkv container (there is no HD sound there initially), with delays, video captions, each audio track, subtitles, and so on
Post by RESET_9999 » Sat Nov 25, 2023 2:18 pm
TheEqualizer wrote: Sat Nov 25, 2023 1:58 pm https://drive.google.com/drive/folders/ ... sp=sharing
your DDP tracks are bluray compliant with an AC3 core and it looks like delay-cut doesn't support this type of audio, unfortunately.
And AFAIK, mp4muxer doesn't support delay. With the latest mp4box, I can set a delay but it doesn't work with the very old mp4box needed for proper DV support in all the devices(except apple)
As for the track names, yes I could keep the original name I guess...
TheEqualizer
Post by TheEqualizer » Sat Nov 25, 2023 2:28 pm
It would be great if you added the ability to completely copy everything from the mkv container.
As for mp4box, and if I don't need the old version, mp4 should only work on relatively new models from 2019 and newer, the latest version of mp4box copes with this perfectly
Post by RESET_9999 » Sat Nov 25, 2023 2:39 pm
TheEqualizer wrote: Sat Nov 25, 2023 2:28 pm It would be great if you added the ability to completely copy everything from the mkv container.
yes you can try the new mp4box but you will have to use a very old version of the script (when I had Apple Mp4 workflows) because the newest script uses delay cut even when it's set to use the new mp4box.
I'm not sure I care enough about MP4 and those bluray compatible DDP tracks since they are very rare on retail discs and non-existent on streaming.
I know they can be encoded from lossless but the tracks I tested so far are bad quality IMO. I can even hear it in your sample, original and custom doesn't sound the same.
TheEqualizer
Post by TheEqualizer » Sat Nov 25, 2023 2:52 pm
Can you tell me which version of the script I need?
And when to wait for changes so that all signatures from mkv are saved
Post by RESET_9999 » Sat Nov 25, 2023 2:55 pm
I'm not sure, look for a version with the mp4muxer workflow (7)
https://drive.google.com/drive/u/1/fold ... 44Memutbpr
I'll try to find time next week but I will not touch the old script versions
johnjon94
Post by johnjon94 » Sun Nov 26, 2023 4:05 am
Would you mind describing how you managed to create the 7.1 channel DDP audio file? I've been experimenting with different Dolby tools but I can't seem to figure out how to get a proper 7.1 channel DDP Atmos file with a 5.1 core
TheEqualizer
Post by TheEqualizer » Sun Nov 26, 2023 7:46 pm
johnjon94 wrote: Would you mind describing how you managed to create the 7.1 channel DDP audio file? I've been experimenting with different Dolby tools but I can't seem to figure out how to get a proper 7.1 channel DDP Atmos file with a 5.1 core
It's impossible to tell it so easily. You need a lot of tools, Davinci Resolve, Dolby Media Encoder, eac3to, command line and some knowledge)
Trees
Post by Trees » Sun Nov 26, 2023 8:43 pm
RESET_9999 wrote: Fri Nov 24, 2023 10:56 pm
Trees wrote: Fri Nov 24, 2023 10:55 pm Thanks brother. I'll wait patiently. :)
no need to wait, I already released a fix a couple of hours ago. :)
That was quick! It worked straight away. Twice. After that I got the following errors:
Donate: https://www.paypal.com/donate/?hosted_button_id=6ML5KUZG9XGB6                      Date: 11/24/2023 10:57 PM
  Contact: R3S3T_9999@proton.me                                                              Version: 1.9.8.3_MKV
                        _____    __      ___       _____           _       _
                       |  __ \   \ \    / (_)     / ____|         (_)     | |
                       | |  | | __\ \  / / _     | (___   ___ _ __ _ _ __ | |_ ___
                       | |  | |/ _ \ \/ / | |     \___ \ / __| '__| | '_ \| __/ __|
                       | |__| | (_) \  /  | |     ____) | (__| |  | | |_) | |_\__ \
                       |_____/ \___/ \/   |_|    |_____/ \___|_|  |_| .__/ \__|___/
                       -Author: RESET_9999--------------------------|__|-----------
 Choose a mode...
1) MODE.I=  DoVi Inject/Convert/Edit/Re-sync TWO INPUTS (P8 Hybrid Maker/Injector)
2) MODE.F=  DoVi Fix/Edit/Extract/Verify/Info ONE INPUT
3) MODE.H=  DoVi Maker from HDR10 (Dolby Algo or MadVR or HDR10+)
4) MODE.7=  DoVi Profile 7 Input (MKV/BDMV)
5) MODE.B=  DoVi MKV Batch Muxer
6) MODE.P=  Plotter
7) MODE.S=  Screenshots & Player
8) MODE.M=  MIXED: Audio/Remover/Encoder/Playlist/Sample
9) Exit
Choice? [1,2,3,4,5,6,7,8,9]?3
                                           * CHOOSE A MODE *
1) MODE.1= CM_analyzer HDR10 to DoVi maker(can batch) (Professional CM v4.0 Dolby Algo)
2) MODE.2= HDR10(madVR) or HDR10plus to DoVi maker (Not Recommended)
3) MODE.3= BATCH convert HDR10plus videos to DoVi (Not Recommended)
4) MODE.4= Batch measure a folder with mkv HDR10 files
5) MODE.5= Back to main menu
Choice? [1,2,3,4,5]?1
-- Input must be HDR MKV/TS/M2TS/MP4/MOV(prores) for the video and the external files: MDL5-bat/xml/rpu/json/txt
-- Input can be a folder or a single file
-- Input with ")" in the filename will NOT work and [] in the filename is not allowed by dolby tools
-- This workflow will convert an HDR10 video to DoVi using official Dolby Vision tools
-- Require Dolby metafier.exe , cm_analyze.exe, lavfilter, madvr and avisynth+
-- https://customer.dolby.com/content-creation-and-delivery/dolby-vision-professional-tools
-- L1 analysis tuning can be configured at line 95
-- if no external shot and If input has dynamic metadata, it will use its scene cuts.
-- If input has no dynamic metadata and no external list, madvr will be used for the shot list
-- You can force frame by frame(line 99) and  You can disable indexing at line 135
-- if you dont provide external config.bat, the same L5/MDL will be used
-- External files: must be same path/filename as input. (bat/xml/rpu/json/txt) external files are prioritized.
-- External files will be moved into the output_path, do not move nor delete them until the script has been completed-- "IGNORERPU" in the filename will ignore the rpu within the video and force madvr
Drag and drop folder with HEVC video files or a single file and press enter...
"E:\Movie_Tools\DoVi_Scripts\The Grand Tour\Series 1\S01E03 - Opea, Arts and Donuts 2160p HDR10 Amazon WEB-DL.mkv"
 BL Mastering Display Luminance and Colors:
 min: 0.0001 cd/m2, max: 1000 cd/m2 Display P3
What is the Mastering Display? Choices are: 1000nits-P3= 20(default) / 1000nits-BT2020= 21 / 4000nits-P3= 7 / 4000nits-BT2020= 8 / 2000nits-P3= 30 / 2000nits-BT2020= 31
20
Manual or Auto L5... a or m ? and/or press enter... (default=m)
a
Processing:  "S01E03 - Opea, Arts and Donuts 2160p HDR10 Amazon WEB-DL.mkv"
reading input tracks format/id/language...
done.
Making a small sample from the input...
Done
Measuring the letterbox...
Done
--> left border: 0
--> right border: 0
--> top border: 0
--> bottom border: 0
Extracting track 0 with the CodecID 'V_MPEGH/ISO/HEVC' to the file 'E:\Movie_Tools\DoVi_Scripts\temp.folder77\BL.hevc'. Container format: HEVC/H.265 elementary stream
Progress: 100%
Reordering metadata... Done.
Reading parsed dynamic metadata... Done.
Generating and writing metadata to JSON file... Done.
error: invalid value ' Arts and Donuts 2160p HDR10 Amazon WEB-DL.scene.cuts.txt' for '--data <data>'
  [possible values: all, scenes, level5]
For more information, try '--help'.
Exporting shots list from a HDR10plus JSON to a text file...
Could Not Find E:\Movie_Tools\DoVi_Scripts\temp.folder77\S01E03 - Opea, Arts and Donuts 2160p HDR10 Amazon WEB-DL.scene.cuts.txt
Indexing, please wait... 100%
Writing index... done.
Input #0, avisynth, from 'E:\Movie_Tools\DoVi_Scripts\temp.folder77\script.avs':
  Duration: 01:02:25.99, start: 0.000000, bitrate: N/A
  Stream #0:0: Video: rawvideo (Y3[11][10] / 0xA0B3359), yuv420p10le(tv, bt2020nc/bt2020/smpte2084, progressive), 3840x2160, 23.98 fps, 23.98 tbr, 23.98 tbn
Stream mapping:
  Stream #0:0 -> #0:0 (rawvideo (native) -> prores (prores_ks))
Press [q] to stop, [?] for help
Output #0, mov, to 'E:\Movie_Tools\DoVi_Scripts\temp.folder77\S01E03 - Opea, Arts and Donuts 2160p HDR10 Amazon WEB-DL_prores.422.mov':
  Metadata:
    encoder         : Lavf60.3.100
  Stream #0:0: Video: prores (apch / 0x68637061), yuv422p10le(tv, bt2020nc/bt2020/smpte2084, progressive), 3840x2160, q=2-31, 200 kb/s, 23.98 fps, 24k tbn
    Metadata:
      encoder         : Lavc60.3.100 prores_ks
frame=89814 fps= 16 q=-0.0 Lsize=101143047kB time=01:02:25.95 bitrate=221189.2kbits/s speed=0.685x
video:101142002kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.001033%
Copyright (c) 2013-2023 Dolby Laboratories, Inc. All Rights Reserved
11/26/2023/15:37:42.459000000 CPU:         Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz (GenuineIntel) [ mmx sse sse2 sse3 ssse3 sse41 sse42 avx ]
11/26/2023/15:37:42.607000000 cm_analyze: Shot cut detection is disabled when shot list is used
11/26/2023/15:37:42.608000000 cm_analyze:                Source: 'E:\Movie_Tools\DoVi_Scripts\temp.folder77\S01E03 - Opea, Arts and Donuts 2160p HDR10 Amazon WEB-DL_prores.422.mov'
11/26/2023/15:37:42.608000000 cm_analyze:        Master Display: 1000-nit, P3, D65, ST.2084, Full
11/26/2023/15:37:42.609000000 cm_analyze:              Src Info: '3840x2160x3 u16 interleaved 422 le tight 0-89813 23.976fps top_left pq ycbcr_bt2020 video bt2020'
11/26/2023/15:37:42.610000000 cm_analyze:                Frames: 0 - 89813
11/26/2023/15:37:42.610000000 cm_analyze:            Frame rate: 24000/1001
11/26/2023/15:37:42.611000000 cm_analyze:     Algorithm Version: 4
11/26/2023/15:37:42.611000000 cm_analyze:           XML Version: 4.0.2
11/26/2023/15:37:42.612000000 analysis: analyzing 0 frames
11/26/2023/15:37:42.612000000 cm_analyze: Shot Info Frames: -1 - -1
11/26/2023/15:37:42.636000000 cm_analyze: Metadata aspect ratios: canvas 1.777778e+00, image 1.777778e+00
11/26/2023/15:37:42.640000000 cuda: initializing CUDA
11/26/2023/15:37:42.751000000 cuda: using CUDA version 9.2.0
11/26/2023/15:37:42.752000000 cuda: NVIDIA GeForce GTX 1070: compute 6.1, cores 1920*1771MHz, memory 8191MB
11/26/2023/15:37:42.834000000 stage: ERROR Stage Reader: Could not find chunk for frame -1
11/26/2023/15:37:42.839000000 cm_analyze: Metadata saved to 'E:\Movie_Tools\DoVi_Scripts\temp.folder77\S01E03 - Opea, Arts and Donuts 2160p HDR10 Amazon WEB-DL_DV.xml'
Removing L2 trims.
11/26/2023/15:37:49.969000000 metafier: Trim to be removed (L2,27) not found in Metadata
11/26/2023/15:37:49.970000000 metafier: Trim to be removed (L2,28) not found in Metadata
11/26/2023/15:37:49.970000000 metafier: Trim to be removed (L2,48) not found in Metadata
11/26/2023/15:37:49.971000000 metafier: Trim to be removed (L2,49) not found in Metadata
11/26/2023/15:37:49.972000000 Metadata: ERROR list of ERRORS/WARNINGS:
WARNING: Update CMv2.9 metadata using ./metafier --update-cm29-metadata
ERROR: No Shots found
WARNING: No L2 Trims found
WARNING: No L8 Trims found
11/26/2023/15:37:49.973000000 metafier: ERROR Invalid Metadata
Generate RPU from XML
Parsing XML metadata...
Error: The system cannot find the file specified. (os error 2)
Error: expected value at line 21 column 35
Parsing RPU file...
Looks like the XML is missing or something?
Post by RESET_9999 » Sun Nov 26, 2023 9:54 pm
Trees wrote: Sun Nov 26, 2023 8:43 pm That was quick! It worked straight away. Twice. After that I got the following errors:
looks like the coma is causing issues so remove special characters from the input filename.
TheEqualizer wrote: Sat Nov 25, 2023 1:58 pm possible to somehow save all the signatures that were in mkv,
https://drive.google.com/file/d/1uPUWSF ... sp=sharing
johnjon94
Post by johnjon94 » Mon Nov 27, 2023 4:06 am
TheEqualizer wrote: Sun Nov 26, 2023 7:46 pm
I likely have all of the same tools as you. I've been decoding the Atmos tracks then importing those into Dolby Media Encoder to encode using the 7.1 DDP Atmos Bluray profile. But the resulting file always ends up with the below channel layout -
Audio
Format                                   : E-AC-3 JOC
Format profile                           : Blu-ray Disc
Codec ID                                 : A_EAC3
Duration                                 : 1 h 45 min
Bit rate                                 : 1 664 kb/s
Channel layout                           : L R C LFE Ls Rs Tfl Tfr
Stream size                              : 1.23 GiB (6%)
Is there any re-mapping that you do to get the L R C LFE Ls Rs Lb Rb layout?
Gatorman
Post by Gatorman » Mon Nov 27, 2023 8:34 pm
johnjon94 wrote: Mon Nov 27, 2023 4:06 am
Even using these processes, isn't the object metadata lost?
TheEqualizer
Post by TheEqualizer » Mon Nov 27, 2023 9:51 pm
