Is there a way to disable M2TS verification?
RickDePepe
Post by RickDePepe »
Hello everybody,
I have issues ripping Doctor Who Season 6, Disc 5.
Episode 10 works fine, but the M2TS check for episode 11 will abort the process at the very end of the episode.
This means I think I can perhaps live without the very last seconds of the episode.
Is there a way to disable the M2TS verification for such cases?
Sure, I will need to double check the output file but I think it will be fine.
BTW: The disc has no visual scratches, was cleaned and the drive usually works fine.
The second drive I have, will have the same result.
Thanks a lot.
Re: Is there a way to disable M2TS verification?
In MakeMKV, unknown - it tries very hard to maintain integrity of the video, and reject bad files,
