Jurassic World Ultimate Collection Dumps Submitted
fermi
#1 Post by fermi » Thu Nov 23, 2023 3:51 pm
I recently purchased the Jurassic World Ultimate Collection, and MakeMKV was unable to decrypt the following UHD discs:
  • Jurassic World
  • Jurassic World: Fallen Kingdom
  • Jurassic World: Dominion
I sent two dumps to svq@makemkv.com on 11/22/23 and the third on 11/23/23.
Jurassic World Dump File Name:
MKB20_v61_JURASSIC_WORLD_8055.tgz
Jurassic World: Fallen Kingdom Dump File Name:
MKB20_v61_Jurassic_World-_Fallen_Kingdom_B509.tgz
Jurassic World: Dominion Dump File Name:
MKB20_v76_JURASSIC_WORLD_DOMINION_D159.tgz
Re: Jurassic World Ultimate Collection Dumps Submitted
#2 Post by MartyMcNuts » Thu Nov 23, 2023 9:47 pm
fermi wrote: Thu Nov 23, 2023 3:51 pm I recently purchased the Jurassic World Ultimate Collection, and MakeMKV was unable to decrypt the following UHD discs:
  • Jurassic World
Jurassic World Disc Info:
Label: JURASSIC_WORLD_DOMINION
Timestamp: 2022-06-16 16:22:42
Protection: AACS2.0/C v76
Data capacity: 87.62 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Jurassic World: Fallen Kingdom Disc Info:
Number of layers: 3
Jurassic World: Dominion Disc Info:
Number of layers: 3
You have inserted the same info 3 times. Anyway, we don't really need that disc info. What would be good is if you could post the dump file names.
fermi
#3 Post by fermi » Fri Nov 24, 2023 1:32 pm
My bad. I edited the original post to include the file names that I submitted. How are the file names helpful?
#4 Post by MartyMcNuts » Fri Nov 24, 2023 9:34 pm
fermi wrote: Fri Nov 24, 2023 1:32 pm My bad. I edited the original post to include the file names that I submitted. How are the file names helpful?
When others try their discs, they can compare their dump file names with those in this thread to see if they are different and need to be sent in.
Radiocomms237
#5 Post by Radiocomms237 » Fri Nov 24, 2023 11:03 pm
Different pressings of the same title will generate different dumps and require different decryption keys.
For example, a US UltraHD release of "Jurassic World" won't (or at least, may not) decrypt even if a dump from the UK release of the same movie has previously been submitted and had keys added.
Posting the file name of the dump allows people to see if their exact release has already been submitted.
I've read that submitting additional dumps of those already sent may sometimes be helpful too. Although I'm guessing that, at some point, flooding Mike (or whoever is doing the key generation) with tons of identical dumps could be somewhat time-consuming to sift through.
mdeguzman
#6 Post by mdeguzman » Sat Jan 25, 2025 3:24 am
Attached is the dump file for Jurassic World also for the Dark Knight Rises. Please help.
Thanks.
#7 Post by SamuriHL » Sat Jan 25, 2025 3:43 am
Both of those titles are in the keydb. If you're on windows, you can use my tool. See here:
viewtopic.php?f=12&t=16883&p=166510#p166510
mdeguzman
#8 Post by mdeguzman » Sat Jan 25, 2025 7:20 pm
I use a mac, will this work? or is there a way for it to work on a mac?
#9 Post by SamuriHL » Sat Jan 25, 2025 7:28 pm
Om mac you'd have to download the keydb directly then unzip it into the directory where your tgz files are created.
mdeguzman
#10 Post by mdeguzman » Sat Jan 25, 2025 9:38 pm
Thank you. Forgive me for my ignorance, but where can I locate "unzip it into the directory where your tgz files are created"?
#11 Post by SamuriHL » Sat Jan 25, 2025 10:02 pm
When you open a disc that MakeMKV does not know how to deal with, it'll tell you where the tgz dump file is created. That's the same location that you need to put the unzipped KEYDB.cfg file.
(Given that you attached them to this thread, I'm assuming you knew where to find them....that's where it goes)
mdeguzman
#12 Post by mdeguzman » Sat Jan 25, 2025 11:28 pm
Thank you
mdeguzman
#13 Post by mdeguzman » Sun Jan 26, 2025 1:09 am
It worked. Thank you.
