Oppenheimer (2023)
irving9901
Re: Oppenheimer (2023)
#76 Post by irving9901 » Fri Nov 24, 2023 6:20 pm
hunk. wrote: Fri Nov 24, 2023 5:25 pm
irving9901 wrote: Fri Nov 24, 2023 2:22 pm I was able to play the 3CB4 via VLC as arthomnix described. But I do not understand how to rip with ffmpeg. How to find out the name of my drive device (Libre Drive: ASUS USB-Device) in the /dev-String? Is there a connection between VLC and ffmpeg?
To get ffmpeg to work on Windows, you need the following folder structure:
ffmpeg folder:
ffmpeg.exe
libaacs.dll
libbdplus.dll
libbluray-awt-j2se-1.3.4.jar
libbluray-j2se-1.3.4.jar
libgcrypt-20.dll
libgpg-error6-0.dll
%ProgramData%\aacs:
keydb.cfg
Then you run (if your bluray drive is D:) :
ffmpeg -i "bluray:D:" -c copy -map 0 Oppenheimer.mkv
Thank you hunk & arthomnix for your help. Will try again on monday, unless we see support for 3CB4
yingste
#77 Post by yingste » Fri Nov 24, 2023 6:30 pm
bay73 wrote: Fri Nov 24, 2023 10:00 am Hello,
UK user and have successfully ripped 100+ UHD's with makeMKV but have hit a brick wall with my Amazon sourced Oppenheimer disk.
Not sure if there is anything I can do? I'm not techie at all so not sure what info I can post here to get some advice? But this is the error message I get:
Using LibreDrive mode (v06.3 id=866A98CB9C4E)
Saved AACS dump file as C:\Users\User/.MakeMKV/MKB20_v77_Oppenheimer_3CB4.tgz
Any help would be appreciated. Thanks
Also having issues with an Amazon sourced disk, 9DF6. Getting read errors at the ~30gb mark. Running it through ddrescue since yesterday and it is still working through the lats 1.5GB.
noworries1968
#78 Post by noworries1968 » Fri Nov 24, 2023 9:06 pm
Same problem w/ read errors @ 30GB's, as well.
mw2002
#79 Post by mw2002 » Fri Nov 24, 2023 10:54 pm
ffmpeg folder:
ffmpeg.exe
libaacs.dll
libbdplus.dll
libgcrypt-20.dll
libgpg-error6-0.dll
%ProgramData%\aacs:
keydb.cfg
Just for reference, I managed to rip 3CB4 on Windows, with only the following in the bin directory,
ffmpeg folder:
ffmpeg.exe
libaacs.dll
libbdplus.dll
And updating the C:/Program Data/AACS/keydb.cfg file to the latest copy.
Happy to have my copy of Oppenheimer :D
pronta
#80 Post by pronta » Fri Nov 24, 2023 11:24 pm
Am I gonna have to figure out how to install libaacs or will we eventually get the key for 3CB4? I really wanna rewatch this film. Have even backed up disk to speed things along if the key ever comes. Is this wait time normal?
Khaaan
#81 Post by Khaaan » Sat Nov 25, 2023 2:11 am
Add me to the list of disc failure around the 30/GB mark. tried 3 different drives, but nothing working with makeMKV for this movie disc.
EDIT: Also looks like Target, Walmart, Best Buy and Amazon are all out of stock. My new order on Amazon doesn't come till Jan.
FFROSCH
#82 Post by FFROSCH » Sat Nov 25, 2023 5:45 am
I have submitted the MKB20_v77_Oppenheimer_3CB4.tgz
fedor
#83 Post by fedor » Sat Nov 25, 2023 10:25 am
fedor wrote: Fri Nov 17, 2023 12:40 pm Dump sent
MKB20_v77_OPPENHEIMER_3CB4.tgz
Still no avail. takes ages :(((
fedor
#84 Post by fedor » Sat Nov 25, 2023 11:07 am
mw2002 wrote: Fri Nov 24, 2023 10:54 pm
Ok. ffmpeg with fresh key file seems doing its job as we speak. on a mac.
thanks for a tip guys!
Trickyd-1
#85 Post by Trickyd-1 » Sat Nov 25, 2023 12:04 pm
MrPenguin wrote: Fri Nov 17, 2023 3:49 pm I am curious - isn't this disk scheduled to be released on November 21st? And Amazon is predicting that I still won't receive mine until 28th. So how can you have received yours already?
They keep doing this to me as well. Yet they offer it on release day “for delivery tomorrow”
Starting to wonder what’s the point pre ordering.
Simbo
#86 Post by Simbo » Sat Nov 25, 2023 12:33 pm
So if people are managing to rip this using alternative software does that there is a key out there? I’ve found a newer version of the keydb file…is there any way of forcing MakeMKV to read that?
arthomnix
#87 Post by arthomnix » Sat Nov 25, 2023 1:44 pm
Simbo wrote: Sat Nov 25, 2023 12:33 pm So if people are managing to rip this using alternative software does that there is a key out there? I’ve found a newer version of the keydb file…is there any way of forcing MakeMKV to read that?
The unit key for the 3CB4 disc is in the online KEYDB.cfg, which allows any software that uses libbluray/libaacs to read it, but it appears MakeMKV needs the VUK and won't work if there is only a unit key available
arthomnix
#88 Post by arthomnix » Sat Nov 25, 2023 1:59 pm
Since ffmpeg can't read chapters from Blu-Rays, here's the chapter list for 3CB4. You can add the chapters to your MKV with MKVToolNix:
mkvmerge Oppenheimer.mkv --chapters chapters.txt -o Oppenheimer_chapters.mkv
(edit: looks like the attachment didn't work, so I've uploaded it to https://gist.github.com/arthomnix/e0b10 ... e04fe4c56c)
H3cxDev
#89 Post by H3cxDev » Sat Nov 25, 2023 4:04 pm
Yet again, 3CB4 doesn’t work yet for those wondering
#90 Post by SamuriHL » Sat Nov 25, 2023 4:16 pm
It takes Mike 1 to 4000 days to generate keys. Some days he's quick, other times it can take a few weeks. Usually it's in between.
