Post by RESET_9999 » Thu Nov 23, 2023 11:56 am
Trees wrote: Thu Nov 23, 2023 9:39 am Hey all. As of recently, I'm getting the current errors for script 3-1. Worked great in the past, however, it recenty started spitting out errors:
Any ideas as to what it could be?
looks like your scene cuts file is wrong. whats the input release name?
speeddemon
Post by speeddemon » Thu Nov 23, 2023 8:01 pm
I'm getting the error message "DoViBaker: Clip length does not match length indicated by RPU file" in StaxRip after using 7-1. It seems like the EL & RPU are 1 frame shorter at the end than the BL. How can I fix this?
Post by RESET_9999 » Thu Nov 23, 2023 8:26 pm
you can use the ''trim'' function in avisynth
something like that:
bl2 = Trim(bl, 0, -206370)
el2 = Trim(el, 0, -206370)
speeddemon wrote: Thu Nov 23, 2023 8:01 pm I'm getting the error message "DoViBaker: Clip length does not match length indicated by RPU file" in StaxRip after using 7-1. It seems like the EL & RPU are 1 frame shorter at the end than the BL. How can I fix this?
speeddemon
Post by speeddemon » Thu Nov 23, 2023 9:32 pm
RESET_9999 wrote: Thu Nov 23, 2023 8:26 pm you can use the ''trim'' function in avisynth
It's not working for me and I'm trying this...
LoadPlugin("DoViBaker_x64.dll")
LoadPlugin("DGDecodeNV.dll")
bl = DGSource("BL.dgi")
el = DGSource("EL.dgi")
bl2 = Trim(bl, 0, -203758)
el2 = Trim(el, 0, -203758)
DoViBaker(bl2, el2, rpu= "RPU_FEL.bin")
ConvertToYUV420(matrix="2020")
Any other tips?
The RPU reports as being 203758 frames long. I do get an error while processing with 7-1 that says:
Warning: Unexpected RPU NALU found for frame 203757. Discarding.
Post by RESET_9999 » Thu Nov 23, 2023 10:33 pm
i dont know, try to remove or duplicate the last frame in 2-1-1
speeddemon
Post by speeddemon » Fri Nov 24, 2023 3:52 am
RESET_9999 wrote: Thu Nov 23, 2023 10:33 pm i dont know, try to remove or duplicate the last frame in 2-1-1
The problem is that the BL is 203759 frames and the EL & RPU are both only 203758 frames. I can't do that with 2-1-1 though since it'll only effect the RPU, right? Any ideas on how to remove 1 frame just from the BL in the AVS?
Trees
Post by Trees » Fri Nov 24, 2023 9:03 am
RESET_9999 wrote: Thu Nov 23, 2023 11:56 am
"S01E01 - The Holy Trinity Full is SDH 2160p HDR10 Amazon WEB-DL.mkv"
No "(". Purposely removed the "(" and ")".
Post by RESET_9999 » Fri Nov 24, 2023 12:15 pm
Trees wrote: Fri Nov 24, 2023 9:03 am "S01E01 - The Holy Trinity Full is SDH 2160p HDR10 Amazon WEB-DL.mkv"
o yeah, I forgot about the old amazon HDR10plus webdl without a profile. They need --skip-validation in order to extract the metadata/shot list.
will be fixed in the next version.
Gatorman
Post by Gatorman » Fri Nov 24, 2023 2:19 pm
speeddemon wrote: Fri Nov 24, 2023 3:52 am
What about using the Preview tab in StaxRip to ignore the final frame from the BL before encoding?
Post by RESET_9999 » Fri Nov 24, 2023 3:03 pm
Gatorman wrote: Fri Nov 24, 2023 2:19 pm What about using the Preview tab in StaxRip to ignore the final frame from the BL before encoding?
Preview will not work if the script can't be played in the first place.
Anyway, no reason why the trim in avisynth wouldn't work if it's just the BL that need trimming.
TheEqualizer
Post by TheEqualizer » Fri Nov 24, 2023 9:28 pm
RESET_9999, Hi! When using DoVi_Scripts_MP4 (last version) point 5, if you apply an mkv with audio delay to the input, then we get a "broken" mp4 at the output. What is the problem and how can it be fixed so that everything in mp4 is identical to the mkv file?
Input file
https://ibb.co/mzsq3SP
Output file
https://ibb.co/C02ndrm
Post by RESET_9999 » Fri Nov 24, 2023 10:43 pm
thanks for reporting, I'll check it out.
Trees
Post by Trees » Fri Nov 24, 2023 10:55 pm
RESET_9999 wrote: Fri Nov 24, 2023 12:15 pm
Thanks brother. I'll wait patiently. :)
Post by RESET_9999 » Fri Nov 24, 2023 10:56 pm
Trees wrote: Fri Nov 24, 2023 10:55 pm Thanks brother. I'll wait patiently. :)
no need to wait, I already released a fix a couple of hours ago. :)
TheEqualizer
Post by TheEqualizer » Sat Nov 25, 2023 7:40 am
RESET_9999 wrote: Fri Nov 24, 2023 10:43 pm thanks for reporting, I'll check it out.
And also, for interest, I ran the finished movie through the script, the script completely recoded all the sound from eac3 to ac3, spoiling it, he can't just transfer everything from the mkv container to mp4 without changes?
