Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB
mickyp2810
Post by mickyp2810 »
Has anyone come across the below before, can't seem to find a definitive answer. Is it a read error or a decryption error?, Film is Harry Potter & Philosophers Stone 4K, Thanks:
MakeMKV v1.12.3 win(x64-release) started
The new version 1.14.1 is available for download at http://www.makemkv.com/download/
File 00101.mpls was added as title #0
File 00100.mpls was added as title #1
Title #00000.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00007.mpls was added as title #2
Title #00008.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.mpls has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00901.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00005.m2ts was added as title #3
Title #00026.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00087.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00900.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00999.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory D:/Video/Harry_Potter_and_the_Philosopher's_Stone
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '18555205632'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '18555205632'
Failed to save title 1 to file D:/Video/Harry_Potter_and_the_Philosopher's_Stone/Harry_Potter_and_the_Philosopher's_Stone_t01.mkv
0 titles saved, 1 failed
Re: Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB
Post by d00zah »
Try the new version & repost log if it still fails.
mickyp2810
Thanks for the heads up on the update.
Tried again and got this:
MakeMKV v1.14.1 win(x64-release) started
Saved SD dump file as D:/Users/Hive/MakeMKV/dump_SD_FD893331607DDCE3B563.tgz
Downloading latest HK to D:/Users/Hive/MakeMKV ...
Saving 1 titles into directory D:/Video/Harry Potter and the Philosopher's Stone
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '18509002752'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '18510114816'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '18510114816'
Failed to save title 1 to file D:/Video/Harry Potter and the Philosopher's Stone/Harry Potter and the Philosopher's Stone_t01.mkv
Encountered 24 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
I'm thinking it's a read thing as looking at the disk it's far from perfect despite cleaning it.
Post by d00zah »
mickyp2810 wrote:
Sun Nov 11, 2018 8:38 am
Ditto. Clean again, or try a different disc.
mickyp2810
joshuagoard
Post by joshuagoard »
Got the same error trying to rip Transformers The Last Knight...Trying again, will report back.
Post by d00zah »
Did you get this msg after the failure (again)? Read the linked page... fairly categorical.
Encountered xx errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Kada3587
Post by Kada3587 »
Cleaning the disk helped me fix it. Use some alcohol and clean it good. Got mine working.
