Oppenheimer (2023)
ShoutingMan
Re: Oppenheimer (2023)
#46 Post by ShoutingMan » Thu Nov 23, 2023 12:24 pm
SamuriHL wrote: Thu Nov 23, 2023 12:45 am Those are read errors. Either try to clean the disc "even if it looks spotless" or get the disc replaced.
Thanks. I tried again cleaning carefully and it’s still failing around the 33% mark. Both in MakeMKV and AnyDVD. So I’m returning it. Hopefully replacement disc will work.
katja2500
#47 Post by katja2500 » Thu Nov 23, 2023 12:28 pm
MKB20_v77_Oppenheimer_3CB4 Still doesn't work.
GFly91
#48 Post by GFly91 » Thu Nov 23, 2023 12:49 pm
Dump file sent to svq@makemkv.com
MKB20_v77_Oppenheimer_0518.tgz
NGNXM8
#49 Post by NGNXM8 » Thu Nov 23, 2023 2:51 pm
3CB4 still does not work so further waiting is in line.
mw2002
#50 Post by mw2002 » Thu Nov 23, 2023 5:13 pm
Any word on 3CB4 decryption? Hoping to watch it tomorrow night 😁
Simbo
#51 Post by Simbo » Thu Nov 23, 2023 6:09 pm
Ahhhhh the wait is killing me. Desperate to watch this!
popper11
#52 Post by popper11 » Thu Nov 23, 2023 7:22 pm
looking forward to MKB20_v77_Oppenheimer_3CB4.tgz :)
pronta
#53 Post by pronta » Thu Nov 23, 2023 7:50 pm
Mine just arrived and I have 3CB4... want to watch ahhhhhhhhhhhhhhhhhhhhh =o
H3cxDev
#54 Post by H3cxDev » Thu Nov 23, 2023 8:04 pm
Tried 3CB4 right now, and still no luck
arthomnix
#55 Post by arthomnix » Thu Nov 23, 2023 8:06 pm
3CB4 corresponds to the disc ID 0x8C887E9C572BA6B2A2FCFF32EC38A33E81D7D24D, the unit key for which is in the online VUK database and was posted at viewtopic.php?p=143661#p143661. I managed to play my 3CB4 disc in VLC (with libaacs installed and the key in my KEYDB.cfg file) and rip it with ffmpeg (it manages to select the right title automatically, change /dev/sr1 to your drive device):
ffmpeg -i bluray:/dev/sr1 -c copy -map 0 Oppenheimer.mkv
(This only works after attempting to open the disc in MakeMKV to enable LibreDrive mode.)
MakeMKV can't decrypt it, even with the KEYDB.cfg file containing the key in my .MakeMKV directory, presumably because MakeMKV requires the VUK and the key database only contains a unit key.
Mantarochen01
#56 Post by Mantarochen01 » Thu Nov 23, 2023 8:25 pm
3CB4, still not opening sadly :(.
webminster
#57 Post by webminster » Thu Nov 23, 2023 8:31 pm
ShoutingMan wrote: Thu Nov 23, 2023 12:24 pm Thanks. I tried again cleaning carefully and it’s still failing around the 33% mark. Both in MakeMKV and AnyDVD. So I’m returning it. Hopefully replacement disc will work.
I got my copy from Amazon as well. Also disc errors about 3/4 in, cleaning and 2 different drives not withstanding. Requested a replacement, they project replacement delivery on January 11 (!). Sux.
-Alan
#58 Post by SamuriHL » Thu Nov 23, 2023 8:58 pm
And that is why I cry thinking about no more Best Buy steelbooks soon. I don't usually have issues reading those. Discs I've bought on Amazon? 50/50, even with my good drive. This is also why I make a protected ISO as the very first step. Once I have my MKV I delete the ISO but the ISO ensures I can read the entire disc before I put it on the shelf.
#59 Post by dcoke22 » Thu Nov 23, 2023 9:02 pm
SamuriHL wrote: Thu Nov 23, 2023 8:58 pm And that is why I cry thinking about no more Best Buy steelbooks soon. I don't usually have issues reading those. Discs I've bought on Amazon? 50/50, even with my good drive. This is also why I make a protected ISO as the very first step. Once I have my MKV I delete the ISO but the ISO ensures I can read the entire disc before I put it on the shelf.
Why a protected ISO? Why not a decrypted MakeMKV backup?
#60 Post by SamuriHL » Thu Nov 23, 2023 9:03 pm
dcoke22 wrote: Thu Nov 23, 2023 9:02 pm Why a protected ISO? Why not a decrypted MakeMKV backup?
Personal preference. MakeMKV is not the only software I use. A MakeMKV protected (if the key is not yet known) or decrypted backup will work equally well.
