Oppenheimer (2023)
ShoutingMan
Re: Oppenheimer (2023)
Post by ShoutingMan »
SamuriHL wrote: Thu Nov 23, 2023 12:45 am Those are read errors. Either try to clean the disc "even if it looks spotless" or get the disc replaced.
Thanks. I tried again cleaning carefully and it’s still failing around the 33% mark. Both in MakeMKV and AnyDVD. So I’m returning it. Hopefully replacement disc will work.
katja2500
Post by katja2500 »
MKB20_v77_Oppenheimer_3CB4 Still doesn't work.
GFly91
Post by GFly91 »
Dump file sent to svq@makemkv.com
MKB20_v77_Oppenheimer_0518.tgz
NGNXM8
Post by NGNXM8 »
3CB4 still does not work so further waiting is in line.
mw2002
Post by mw2002 »
Any word on 3CB4 decryption? Hoping to watch it tomorrow night 😁
Simbo
Post by Simbo »
Ahhhhh the wait is killing me. Desperate to watch this!
popper11
Post by popper11 »
looking forward to MKB20_v77_Oppenheimer_3CB4.tgz :)
pronta
Post by pronta »
Mine just arrived and I have 3CB4... want to watch ahhhhhhhhhhhhhhhhhhhhh =o
H3cxDev
Post by H3cxDev »
Tried 3CB4 right now, and still no luck
arthomnix
Post by arthomnix »
3CB4 corresponds to the disc ID 0x8C887E9C572BA6B2A2FCFF32EC38A33E81D7D24D, the unit key for which is in the online VUK database and was posted at viewtopic.php?p=143661#p143661. I managed to play my 3CB4 disc in VLC (with libaacs installed and the key in my KEYDB.cfg file) and rip it with ffmpeg (it manages to select the right title automatically, change /dev/sr1 to your drive device):
ffmpeg -i bluray:/dev/sr1 -c copy -map 0 Oppenheimer.mkv
(This only works after attempting to open the disc in MakeMKV to enable LibreDrive mode.)
MakeMKV can't decrypt it, even with the KEYDB.cfg file containing the key in my .MakeMKV directory, presumably because MakeMKV requires the VUK and the key database only contains a unit key.
Mantarochen01
Post by Mantarochen01 »
3CB4, still not opening sadly :(.
webminster
Post by webminster »
ShoutingMan wrote: Thu Nov 23, 2023 12:24 pm Thanks. I tried again cleaning carefully and it’s still failing around the 33% mark. Both in MakeMKV and AnyDVD. So I’m returning it. Hopefully replacement disc will work.
I got my copy from Amazon as well. Also disc errors about 3/4 in, cleaning and 2 different drives not withstanding. Requested a replacement, they project replacement delivery on January 11 (!). Sux.
-Alan
Post by SamuriHL »
And that is why I cry thinking about no more Best Buy steelbooks soon. I don't usually have issues reading those. Discs I've bought on Amazon? 50/50, even with my good drive. This is also why I make a protected ISO as the very first step. Once I have my MKV I delete the ISO but the ISO ensures I can read the entire disc before I put it on the shelf.
SamuriHL wrote: Thu Nov 23, 2023 8:58 pm And that is why I cry thinking about no more Best Buy steelbooks soon. I don't usually have issues reading those. Discs I've bought on Amazon? 50/50, even with my good drive. This is also why I make a protected ISO as the very first step. Once I have my MKV I delete the ISO but the ISO ensures I can read the entire disc before I put it on the shelf.
Why a protected ISO? Why not a decrypted MakeMKV backup?
Post by SamuriHL »
dcoke22 wrote: Thu Nov 23, 2023 9:02 pm Why a protected ISO? Why not a decrypted MakeMKV backup?
Personal preference. MakeMKV is not the only software I use. A MakeMKV protected (if the key is not yet known) or decrypted backup will work equally well.
