Problems with Knights of Sidonia (Movie)
VictorBravoLV1
#1 Post by VictorBravoLV1 » Sun Nov 19, 2023 5:12 am
Hey y'all. I have a problem with one of the Knights of Sidonia discs. The bonuses work fine but it failed to pick up the movie. When I looked up on the logs, I saw this. Is there anything that should be worked around?
004004:10000 The source file '/BDMV/STREAM/00006.m2ts' is corrupt or invalid at offset 6257111040, attempting to work around
005003:0000 Failed to save title 0 to file D:/Video/Knights of Sidonia 21 BD-5/title_t00.mkv
002023:0000 Encountered 7 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
error=0x06031105 count=7 name=Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR
002023:0000 Encountered 150 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/
error=0x070B0D08 count=150 name=Internal error - M2TS hash check failed (3336)
Encountered 5 unclassified errors
error=0xC000009C count=5 name=OS error - STATUS_DEVICE_DATA_ERROR
I attempted this on the NAS, then to my PC, with the LG WH16NS40 but to no avail.
Re: Problems with Knights of Sidonia (Movie)
#2 Post by dcoke22 » Tue Nov 21, 2023 9:06 pm
Those errors typically mean the optical was unable to correctly read the disc. The standard advice is to gently clean the disc and try again.
