I have successfully created the MKV file and viewing it with VTC on Mac is fine.
Now, I am trying to convert via iSkysoft to AppleTV format, and it only puts it into a 4x3 ratio box. The resolution in the options is 1920x720.
Anyone know how to get this to be 16x9 ?
Square Box
Re: Square Box
You would have to disable the cropping to get it back to 1920 by 1080.
While I'm not sure, I think the AppleTV only handles 720 files so you would have to scale it down to 1280 by 720.
SC
SC
