Automatics SDF downloading failed
psycoperl
Post by psycoperl »
Good Morning
I am receiving the following error when I start MakeMKV
Automatic SDF downloading is disabled or failed.
DEBUG: Code 152 at )Sk0=`x9vK.<!TEW:213144911
I checked the MakeMKV Preferences and under General > Online Updates "Enable Internet Access" is checked,
Re: Automatics SDF downloading failed
Check your firewall settings.
psycoperl
Post by psycoperl »
I do not have a firewall, other than my normal router.
Normal steps are
Change your dns away from your isp dns
Check geo blocking servers are in Russia so that can't be blocked.
Use a VPN if none of that works
